Which linkage bolt goes where
I took on the "triangular" shaped part of the linkage and am unsure which bolt goes into the swingarm, the long or shorter bolt..
Try it out,im sure only one bolt fits right.One might be to short to see threads and start your nut, I think you should be able to tell.Most bolts have a little threads showing after the nut is on a tight.
Also how do i fit a socket onto the one linkage bolt that attaches to the framee.. the chain roller mount is in the way and the bolt is TOO tight for a wrench
never mind i found out they are the same size..
