I want to get a xr50, but im 6'3"
hmm, well, would i fit?
My friend Dave is 6'5" i believe and he fits with the with the proper set up. Foward bar set up, Tag mini play bars, XR70 swing arm, tall seat foam, If you have the money chromoly 1" over frame. You dont need the frame but will be in heaven if you get it.
Later Atom RoTTeN
that would look really funny. Whats up with the 50's all the sudden. Who would want a 50 other than a 1st grader.
50's Rule!
i just got a 50 yesterday, it's freaking awsome.
Well mister cogins 911 if you gotta ask you just wont get it! Oh yeah good luck on saving up for that big bore kit for your ttr 225 , I know that it is a bunch of money? :)
why mess around with silly little things like xr50s, when you can have a man's bike like a ttr225?
LOL Motomofo1
Dont say that to loud when an xr50 pilot rails past you! I seen it happen to boys on bigger bikes.
Later Atom RoTTeN
get on aim if you can cuz im bored all heck over here. :)
ive already got $200 saved up. My bike has been lightened, i took the battery out and starter off, and got the kickstarter and got that put in there. Im going to get aluminium wheels on it here in a few weeks. So it should weigh about 220 when im done with it. I think with the big bore kit in there and my exhaust pipe it will havew about 25+hp or maybe less. Its gonna be trick when i get done with it.
cool post pics when your finished... :)
yo 911,
powroll's site says that everything they sell is listed,
yet i dont see where they sell kits for the ttr225 or ttr250?
please help me out here. where did you see them? :)
it was on there about a month ago. you sure you looked good.
I'm 6'2", and with a BBR Triple Clamp/riser/bar kit, Applied heavy-duty shock and fork springs, FiveO Racing reinforced fork legs, and the BBR High Seat Foam, I fit on it. I removed the rear brake pedal and used a BMX perch, lever and cable setup to work the rear brake. It all works for me...
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: http://tboltusa.com/store/lifan-125cc-enginebrsale-price-p-1811.html ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
