KTM's
I'm looking at getting a new bike this year and am looking at the KTM's. i have some questions about them though. Such as the difference in the 520 & 525, the diference between SX< MXC and EXC. I'm in northern Nevada and I ride desert and woods over in Nor.Cal. I'm tring to figure out what bike would do best for my riding situation. maybe even a 450 for the tighter stuff. Any info would be great. What about the Wr450
Thanks
520 and 525 are same engine, just slight year to year modifications. Both are 510 cc's.
KTM designates the new one a 525 to set it apart from the 520 and 450.
I think the biggest changes from the 520 to 525 are the size of the forks (bigger up front on the 525, 48mm WP forks, instead of 43 mm forks....depending on the year 520 you are looking at). The head was modified on teh 525 from the 520, and the crank is lighter. Mostly, again, just yearly upgrades that every company does.
I do not believe they changed the offset of the clamps on the 525SX. (still 20mm) You may want 16, 17, or 18mm clamps, but that is not necessary.
As far as SX, MXC, EXC, the SX is the lightest, meanest and fastest of them. It is the pure all out racing version. It also only has 4 speeds. (But what a set of gears it has)
The MXC is designed for XC riding, or desert. It has a 6 speed gearbox, (same lower 4 as the SX, just 2 more up high), a much larger tank, and an e-start. (Weighing in at about 15 lbs more than the SX, dry)
The EXC has everything the MXC does, but it is equipped with lights.
I personally do not believe the e-start on a KTM is necessary. The automatic decompression (which KTM has used since the 2000 year 400/520's) allows the bike to be kicked like a 2 stroke, just like your CRF.
The SX will wind out in the desert....I had mine tapped on the rev limitter when I was out there, and wished I had more. A gear change would have helped alot, as I was running the stock 14/48.
I don't think the SX is a mistake in the woods though. The light weight of the bike makes it easy to flip around. Adding 15 lbs for an electric start seems odd to me, since I can start my 520 with my hand. I've never had a problem starting, until my plug is shot.
If you are doing alot of desert, or long woods, definitely an MXC or EXC.
As far as displacement, thats up to you. You think the CRF is mean, try a 520/525, and you'll find the Honda to be timid. The bike is easy to ride, smooth, smooth, and more smooth, but if you whack it wide open, it makes a sickening sound and feels like it is ripping itself apart. Your arms will grow, and you'll pull more supermans that any of the pro FMXers.
There is a pretty good amount of compression braking. Unlike the CRF or the new YZF. You can use the engine braking heavily.
The KTM is also not a revver bike. Don't ride it like a Honda, or Yamaha, don't rev it. KTM's 4 strokes make all the power anyone would ever desire from 1/4-3/4 in the RPMS, not 1/2-WFO like the japanese machines.
I dunno if I gave you anything useful, but hey, at least it's something!
  • Similar Content
    • By TheCurtster
      Hi all,
      Well, I’m finally putting my faithful 97 XR400 out to pasture, and have joined the KTM family with a brand new 500 exc.  if Honda would only make a lightweight 400 size dualsport bike, I would....   never mind, that’s a different thread.
      So here I am.  I don’t race, I’m getting old, and this will probably be my last dirt bike I own.  I’d like to keep it for 20 years like I did with my Honda.  I’ll try my best to keep up with the flood of maintenance (what’s the crank rebuild interval for a XR?  40,000 miles?). Anyways, looking for suggestions so I can enjoy this bike into my 70’s.  A skid plate looks to be needed, and some way to tuck the license plate up and still be legal are in my future.  Thoughts?
      Thanks,
      Curt,
    • By Jay_112
      Hey all,
      My name is Jay and i'm new to the forum community but not new to the sport. However I have reached my limit with my expertise and am hoping some of you may be of some help. Without further ado...
        I've stuck to a track most my life, I.E. Motocross, arena cross and outdoor national style tracks. I've made the difficult decision to leave to tracks to the young guns and ride more single track and trail riding up in the mountains. So i started by selling me Factory SLM racing 2012 Yz450F, yes i cried when he drove off with her. But i looked to greener pastures with hopes to have a KTM 500exc, Beta 500rr-s or a Husqvarna FE501. However, almost a year later and I still don't have a shiny new dirt magnet in my shop. I'm in the final deliberations and have narrowed it between KTM and BETA, with me leaning towards the BETA. This is where you come in.
      I would like to know the following.
      Is the Beta service intervals as daunting as the KTM's?
      Is the cost of parts between the two noticeable? And are the just as readily available?
      Those that have a 2017 of either bike, How are they holding up? Can I expect this bike to hold up like a 1985 XR250 (An almost impossible feat)?
      What are any major concerns about either bike?
      and finally what made you choose one or the other?
      Thank you for your efforts and advice. I appreciate it.
    • By jaworskime
      I have had this issue happen twice,  my efi and low fuel light are coming on, the bike will idle but soon as you give it gas it will sputter and die. The lights aren't on until you roll the throttle back.  Any ideas? Also the electric start won't work. Have to kick the bike to start,  and the computer doesn't come on when you turn the key and flip the switch to start,. Assuming it's a wiring  issue or fuel pump issue,  any help would be appreciated.
    • By motf
      quick, question - is it doable without removing the tank?
      thanks
    • By KeyKeeper
      I noticed my shock spring almost touching my exhaust on 06 525exc.  I pushed on the spring with my hand and the swing arm moved over 1/8"!
      I know that cant be right but looking at the schematic view of the bearing layout, wth holds the swing arm from moving side to side?  I see the bearings, sleeve, seals and some small cap type things that go on the end of the sleeves  (outer end) but what actually keep the swing arm from sliding side to side inside the bearings?  Looking at mine there appears to be some sort of spacer on the left side between the swing arm and frame beam but on the right, it just looks like the sleeve mates up to the frame?  Am I missing something on one side?  Got this bike in a trade.  So far the motor has been rebuilt at cannon racecraft in OKC, forks rebuilt, and its super clean and runs great other than it needed valve lash set.  So it seems odd that an important part like a swing arm spacer would be mia.  Any ideas?
