does 02 crf450 have handling problems
i just bought an 02crf450 that i,m going to race harescrambles and mx.i want to know if the handling problems that alot of guys have been talking about is that big of an issue or is it something most of us can live with.it,s way to cold right now to even get some riding on my new bike.
I don't have any complaints with my 02. The biggest problem was the front not grabbing with the stock 490 front. I changed to a 756 front and it was worlds better.
I did just put the the 03 shock linkage on, but haven't had a chance to ride it yet.
Some of the pro level riders I have spoke with said that the 02 felt like riding a "chopper", due to the rake angle of the stock triple clamps. Many have switched to the 22mm offset clamps, available from a few different companies. Also, the front forks may be a bit stiff for hare scrambles. You may want to soften the front end up a bit. Some of the best results have come from removing the "mid-valve" from the front forks. This allows the bike to have a plusher feel. Hope this helps, and win well my friend.
Bob
Triple clamps with 20mm offset will help. They're also expensive. The "Storm" link for the rear shock will also help. It's relatively cheap (around $100) Some people have done both, but many claim both are not necessary. I'd be very surprised if a Storm link and raising your forks in the stock clamps won't treat you right. Good luck with it.
I put the 2003 linkage on my 2002 CRF and it improved the handling (the front end felt more planted in fast sweepers). I purchased it on EBAY for $160.00 delivered. I also sold my 2002 linkage on EBAY for $95.00 the next week (maybe someone wanted to lower their bike?). This is much cheaper than tripple clamps. I did have to reset my rear sag. It did raise the seat a little, but I am 6'2. :)
I have both 02' and 03' crf's. I rode both bikes back-to-back and YES you can feel the difference. 02' does not turn as well. But Sunday morning I just got done putting on my 02', Applied Racing 22mm off-set Red T-Clamps(top/bottom)with rubber mount/over sized bar mounts with Fatty Bar(CR High). <font color="purple">Holy Smokes it does make a difference......for sure!!
I did the test again. Rode both bikes back-to-back for about an hour and my 02' handle's better altogether. Just like my 03'....100%.
I've been on this site since Oct.1 2001 and heard everybody talking about doing this to the 02' and I thought it turns fine for me. Well they are right......I feel the difference and it looks Great too. :)
Great Sunday ride!!! Had some fun!! :D
Mine turns perfect with a storm link and 22mm clamps.
SAME HERE STORM AND 22MM ARE THE TICKET,AWSOME.
Storm link, new front tire and front forks 4 mm below line has my bike turning great. Was thinking about new triple clamps, but after yesterday at the track , don't think i need them. For the scrambles you may want a steering damper.
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
