mnelson78/Phile
Phile & Matt,just went for my first ride with advanced jetting,unfortunatly I did also add the Power Now bell at the same time.What can I say, it was just the way things went. I'm very happy with the results.I really noticed when I just moved the throttle a hair,it was twice as responsive as it used to be.I'm at the 4th clip, but I did'nt try 5,and I will for the hell of it.It seems like it wines out super fast,(more like a two stroke)than it ever has.I ran a 162mj with the EKP,but could never get it to run good on the 4th clip,only 3rd.I have a question for both of you,I know Matt said to plug all the ports on the choke side off when the coast enrichner was removed,but there's one towards the back side of the main body of the carb,(closest to the rear bell,and it seems to me it ties right into the paj.If you went to unscrew it,just the tip comes off. I hope this is clear to you guys.It had a # on it,I think it was 90?Anyway I always have run it connected with a hose to my air boot?..There's a small brass looking connector coming out the bottom of it.I tried again yesterday,with it plugged,and than connected.My initial feeling was no difference,I would like to know your opionions on this?Thanks guys for alllllll your hard work,(research).
I think I know what you are talking about. I caped/pluged every hole (fuel and air) that was connected to the coasting enrichment system. I figured that the whole circuit needed to be closed. Darn, the DRZ carb is such a hassle that we all seem to do other jetting things when we add the Power Now. If it was easy to just add the Power Now and remove it (like in 5 minutes) then we could test it against the stock carb bell housing - oh well! Glad the advanced jetting helped. I don't run the EKP, but I did run it for a long time with the coast enrichment attached with the old settings of 48 pilot and can't remember the clip position. If I had to guess, I would say C-3. that was with coast enrichment still attached. I run the full Yoshi kit and the EMM C-4 works well. I put in the EMM at the same time that I changed all the jetting 38/73, 180maj, 158main, remove coast enrichment.
  • Similar Content
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
