Race fuel
I was hoping you guys could tell me which fuel is better regarding leaded or unleaded. My freinds tell me I should only be using unleaded race fuel. The dealer said leaded is fine. A car buff freind said lead is good for the valves. I am confused and wondering if you guys run leaded or unleaded and why? I was thinking about VP red which is leaded, or Unocal 100 unleaded.
Hoffy
I have run klotz 112 oct. its leaded, used it in my 450 and
my buddies all year .
I mix it 50-50 with amoco premium gas.
Same plug(no lead deposits)and only had to adjust one intake
valve.
You can buy klotz gas in 5,35 and 55gal.
Look at their web site for dealer location,I am also very
pleased with their 4 stroke oil.
Hope this helps.
Steve T.
I run about 1/3 76 110 and 2/3 pump gas. the bike runs like a champ.
I currently running 100% cam4 110 octane with no problems thus far. I should note however I am running a high compression head. Previous to head work I ran premium pump gas w/o problem.
good question, i've been running sunoco 112 in my '02 crf for about 6 months with no problems at all just wondering if it will damage the bike after time opposed to pump fuel?
Correct me if I'm wrong, but I see no need nor advantage to running race gas through a stock motor? Or is stock compression high enough to justify the added octane rating (above and beyond say premium pump gas at a 94 octance rating)?
Only asking cause i ran mine with 94 for up till last week (had her since fall).
The Chevron where I live has 91 octane premium. I know the octane used is supposed to be atleast 92. If I am on the border with a stock engine I would rather error to the side of caution. I also noticed a difference in performance when I tried a Unocal 100 unleaded. It was slight but I could feel a quicker rersponse. just seemed more "snappy". After consulting with several people I know I decided to use a 50/50 mix with premium and Unocal 110 leaded.
Gstar
If we had 94 octane gas I would run pump gas also.
bla, bla, bla... Just kidding Tuna! Like he said. I'm one of the buddies. :)
Like mxraceraz,
I use 1/3 race gas(VP C-12), and 2/3 91 pump gas on my BRP and CRF with no problems.
I use vp ultimate4. I don't know if it's leaded or not, but it works great. It really adds power. It will stink up your garage, so be sure to keep it in a well ventilated area. I run it 50/50 for playriding, and 100% for race day. This fuel was formulated for our bikes... AMA is considering banning the fuel. That should tell you how good it is.
I have heard that the vp ultimate4 is great for 4-strokes, however, isn't it about $8 or $9 per gallon? They say it adds 2-4 hp.
yeah, it is very expensive. It does add horsepower though. If you figure $40 for 5 gallons, its pretty cheap for 4 extra hp on raceday.
Leaded is good for the valves in your engine, because it lubricates them.
VP makes a cheaper fuel for four strokes as well. It is called 103. It has a 103 octane rating.
One advantage of using race gas over pump for a stock engine is temperature. The race gas burns at a much lower temp., so your motor will not run as hot. This does not help much on the first lap, but after that it is great. When everyone else is losing horsepower from engine heat, you won't. Or at least not as much.
  • Similar Content
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By smythe
      Complete 2009 CRF 450r cylinder head with valvetrain.
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
