Diving into case replacement. Sage advice?
Parts are on the way to replace the cases on my 06. The shift pin broke off a piece of the right side case, which I understand was a fairly common problem and the cases have been updated. This will be my first experience with split cases, so should be a bit of an adventure. Any good tips for things I may run into that the manual may not tell me? Also, if anyone else has had this same failure, did it result in any additional transmission damage?
I also need to get the crankshaft jig tool, anywhere these can be ordered online so I don't have to deal with ordering one at the dealer?
You don't need a jig tool.
First thing you're gonna want to do is build a engine cradle. This is just 2x4s about 12x12 or a little bigger can't remeber how big mine is. Nail them togther. This will allow you to move the engine ect while you work and for it to be cradled.
Second. You need case splitters. Don't split it with screw drivers. and a hammer.
I'm not sure if the new cases come with all the blind bearings allready in it. If not. you're infor a hella of a ride. you're gonna need a blind bearing puller. Or buy new bearings.
Inspect all parts. If you have a parts cleaner clean them throughly. then if you're not doing this in a few days. I generaly just store them in a ziplock bag with a spray of wd40 to prevent oxidation.
Make sure you have good toque wrenches. I have to suggest the digital torque wrench from snap-on. Yeah its exspensive but its not like you'll only use it one time. That can be used on eveything.
DO NOT RE-USE the crank bearings. Buy new crank bearings and seals. Also you'll need a bearing remover for that also. Some time you can use a can of liquid co2 [dry ice] to frease the crank and they sometimes will slip off that way. as far as the bearing remover. well you probably could rent it from autozone..
Good to know on the jig tool. I have a case splitter, and a crappy old bearing puller, but I ordered all new bearings. I also have a parts washer at my bike shop. Torque wrench is on the shopping list, and thanks for the tip on the engine cradle. Wish me luck.
Get new bearings.... trust me. I landed on a rock in late '06 and had to do this.
Even with a blind puller it's a royal pain. You'll need a press also to press the new bearings into place. Just take your time and pay attention to detail. It's really not that hard, just time consuming.
GOOD LUCK! :thumbsup:
I agree with hobandre. and you said you bought new bearings. Yeah its much easier to install new bearings then worrying about screwing up the used ones taking them out..
Yes a press is needed err well advised.
Good luck.. If you can spare the extra money I would just buy a new crank and piston while you have it apart. Unless you only have a few hours on the current crank.
Another 300 for an OEM crank or 225 for a hot rods was just a little more than I felt I could justify putting into the bike. New piston is on the way. I spent just under 1000 for the cases, bearings, piston, and gaskets at Motosport. I dont know how many hours exactly are on the crank. Supposedly the motor was all fresh when I got the bike back in the spring, and I was a relative beginner when I got it so the abuse hasnt been too bad. I was tempted to sell the bike as is or part out and grab a 450, they are being given away right now, but decided I wanted to stay on the 250 through the winter. Plus while I have it apart I am cooking up something pretty special for it in the styling department:rolleyes:
Take your time!!
  • Similar Content
    • By Robert Rice
      Okay so I picked up a 2018 kx250f the other week and took it riding and it was BAD ASS! I have a 2002 ktm125sx and it’ll whoop that thing any day! I’m going to the sand dunes this weekend and gonna use the 6 paddle I used on my 125. Should I be using an 8 paddle with a larger rear sprocket? I wouldn’t want my first experience in the dunes on this bike to be a bummer just because I had the wrong paddle on.
    • By TPA-MX
      Hi guys,
      I have a 2014 KX250f that has a super small hairline, I mean super small hairline crack just under the main engine plug hold on the ignition cover.  You cant really see it, but it "slowly" will leak oil out if let set long enough.
      I would like to permanently fix it.  Right now, I just used some clear silicone on the outside and it stoped the leaking.  However, looking to sell the bike and I want more of a permanent fix.  The 3 options I see are:
      Replace just the ignition cover Replace the entire Stator/ignition cover Use some jb weld on the outside, sand down and paint My questions are:
      On #1, how hard would it be to use my existing stator / magneto items and install in a new cover? On #3, can JB Weld be grinded/sanded down to a smooth finish?  If so, what is the best material to use?  Regular wet/dry sandpaper?  If I go this route, I would want it to look decent, then paint the entire cover black with hi-temp black paint.   What would you recommend?  Am I missing any other alternatives?   Thanks!
    • By rollin30
      I need a subframe for a kx250f and an exhaust system too
    • By rollin30
    • By Andrew Oberther
      I picked up an 09 kx250f as a winter project and it had a chewed up head, and is unrepairable. I was online and found a 2011 kx250f head and was wondering if it would fit. Thanks.
