No video, no riding
Well this weekend was a bust, I was going to do some riding upnorth with the studded tires. And even get some video...
Unfortunately the bike wouldn't start. I guess it was too cold and the battery may have been low. So I charged the battery with a trikle charger, got it running, and found out it would die without being given throttle. So it wont idle.
My thoughts are to check the carb's idle jet, and the spark plug while I'm at it.
I guess I'll get some video another time, right now I think bed sounds good
Yep in the cold cold weather it takes awhile to get started sometimes...
Its just that whole not idleing thing which will have me opening the carb up tommorow. IF I have time :)
You guys are nuts! :)
I didn't go sledding today because I thought it was to cold, never mind riding! :D
it was -25 when we got up there. (near algonquin park sorta)
it warmed up to about -13, -10 around there.
When I got home it was -6. Me and my budy went to get a movie at the movie store. I went in my t-shirt because it felt so warm out :)
You guys are so lucky.
It's 37 degrees celcius here today and it seems like the whole country is on fire.
Roll on winter !!!
Mike. :)
Good trick I've used a few times for startin the bike up in real cold temps (5 F this mornin) is to heat the carb up for a few minutes with a blow-drier or high wattage light. After about 5 minutes of heating up the carb she starts right away with just choke on (and maybe a twist) and stays running. Of course that doesn't help much on the trail...unless you pack the carb in those hand warmer packets. :)
Problem solved.
Something must have been dirty and cleaned itself. After taking a 15 minute ride, keeping the rpm's off bottom so it wouldn't stall while off the gas, the bike seems to idle great now. I'll asume either the pilot jet cleaned itself out, or the spark plug burned itself clean.
:) 4 strokes are great :D
  • Similar Content
    • By Caycee Justus
      I had a gsx-s750 and got rid of it and picked up a 2015 drz400sm this week. It's used and the last guy put knobbies on it. I'm switching back to Michelin power 2ct. stock tire size is 140/70. The current tires are 150/70. I was looking at running 160/60. Anyone know if this would be a problem? I'm just getting into the supermoto life so any other general suggestions would be great. Thanks!
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
