"S" or "E" blown fuse
Can you bump start with a blown fuse? I used my back up today and if that blew too :) would I be SOL .
Isn't it just a regular car fuse? I'm pretty sure it is, go buy some of the same rating. no big deal. I belive without the fuse in the bike will have no spark or anything.
I'm planning on buying a few back-ups.
They are just ATC Buss fuses, 10 amp stock (for E any how) but I got a pack of 15's taped under the side cover just in case. Get em at auto-zone or something. :)
Of course if you are in a real tight pinch and know there is not a short somewhere I have used bubble gum wrapper in there. :D It won't start at all without the fuse etc.
on my first big get off i blew the fuse on my KLXS, it would not push start.
Good thing it came with a backup in the little black holder next to the orig.
I would have been SOL 20 miles from nothing and pushing...
The KLXS takes a 20amp.
Not even sure the kick start add on would have helped me... :)
the fuse has to good for the bike to start regardless.check your wirign harness where it goes past the steering head.they tend to get pinched there and cuases the fuse to blow.
i have several fuses taped in side my air filter door.just in case.
I have had that pinched wire problem, so check it out.
Also if you use the fuse, make sure you replace the extra one inthe holder with a good one.
I found out the hard way that the previous owner had used the extra fuse in mine and he put the blown one back in the holder. Luckily another rider had a fuse for me.
What is this "pinched wire problem" I want to know ahead of time in case my 'S' dies at some point. Thanks.
where the wiring harness passes the steer tube it can fall down and get pinched between the frame and steering stop.
Ahh, I get it. Thanks, I will keep an eye on it.
I had a little get off and the wires pulled off the front brake light switch. I inspected the wiring and all looked good I insalled th BU fuse and all was well, but was worring, what if there was still a short and the 2nd fuse blew. I'll carrie a few for now on.
A friend with a KTM was having a problem with blown fuses and it turns out that he pinched the wire from the start button with his tie down. Another place to look if the problem persists.
Out of curiosity, I just removed the fuse from my "E" and, with the key on, kickstarted it. Can't say if this would hold true for the "S" model.
I could be wrong, but I think the fuse on the S model is a size 20, not 10. Don't have bike with me to check, but it's yellow one at Radio Shack, if that helps...
Yes the "S" has a 20 amp fuse. I blew one at a race last weekend because the headlight plug got crushed in the steering lock (headlight was removed). I had no spare because I blew one before that and forgot to replace it. It took 2 hours to get going because I had to make a bypass out of a piece of metal. It was a pain in the a$$ but it got me to the finish line, deadlast though :)
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
