polishing question
i was wondering if i could polish the rims on my 07 with mothers aluminim polish?
You can but you will umm be doing it for a long time..
Start out with some 500grit wet/dry sand paper
then move to 700grit, then 1000grint I even went to 2000 grit and finished off with mothers.
On a side not. I only did the top spars that go from the head around the tank to the giant weld. No futher. That was time consuming. Did look real good though.
Umm I just knoticed you asked about your rims..
No, they are anodized and mothers doesn't polish the clear coating produced by the anodizing proccess, you can seach for an anodizing polish. but if its scratched real bad you're not realy gonna be able to do anything for it.
okay yeah i poloshed my frame spars to a mirror it looks so sweet. after the first time it doesnt take hlf the time of the first time but yeah i think ill just stick with the spurs cause that sounds like it would take a while. and yeah my rims are a little scratched up. thanks for your help!
mothers takes for ever, if u can find it use MIRROR FINISH POLISH
what does the bottle or whatever it come in look like and where did u get it i got mothers at walmart!lol and im going back to get some magic erasers they work sweet on the frame.
Make sure you use the paste Mother's Polish in the little, white can. The paste works MUCH better than the liquid stuff.
yeah i bought th emothers it works great except it leaves nehind a little bit of the black color????????
All polish should leave behind a black color if it's working. Its turns black from the dirt coming off the aluminum. After a while of wiping just wipe off the black residue with a clean rag.
what does sanding do to the metal? At first it sounds a little iffy
like when i say black its after i take most of the polish off do i need to just keep going? and is there anyway to get rid of the swirl marks on my frame? they are more noticable after i polish it.
The swirl marks are usually scratches. Use a finer polish or some really really fine sand paper. I have never used sand paper, but i would imagine it takes the scratches out, i would go over with polish after.
But yes to get the black stuff off, just keep going. Eventually it will come off.
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
