Shock Repair?
I have the chance to get a shock with the high and low speed compression dampening and rebound dampening from a DRZ\KLX. The center screw for the dampening is stripped out and I'm wondering what it would cost to repair it. I'd have changed the oil in the shock and have it recharged before I used it anyway so that cost was already considered.
Thanks,
I would try some one like Race Tech or RG3 as the work on them all the time and probably have all parts for it or at least know where to get it, they could rebuild it for you too.
repair and replacement parts are not available from the OEM... So you will have to find a suspension shop that has access to repair parts or a supply of good used parts (so a larger shop, Race Tech, or my Favorite MX-Tech East Coast Suspension The part can be replaced simply once the gas charge has been relieved, it's getting that part and recharging the shock that you'll need help with.
Contact a shop, figure in the repair price, looking for a better deal may end up the better fiscal choice.
  • Similar Content
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
