Front brakes - steel braided lines?
The forks are off and the front brake is just hanging there. I have never been to happy with the front stopping power of my DRZ. I have bleed them more than once to make sure that the system is air free. How much will a new steel braided line help my front stoppers? (a little, quite a bit, or lots?) And what company(s) makes them, who is the best one, and where can I get it at the best price? This is the time to do it - if I'm gunna! Burned, can you get me a master off of a used newer RM or CR or something? The newer masters are better that the DRZ's - right? When I ride my friends CR450, the front brakes make mine feel even worse!! You can only ride as fast as you can stop!!
the braided line makes a big difference.i would do that rather than the master first.if you still arent happy,check ebay.lots crf and yzf being parted out for quads!master should be easy to find.
i went to a braking over size rotor also!now im happy with the brakes.i like to be able to do stoppies on the down side of jumps.stock drz brakes will not do it!now its 2 fingers easy!
I'll sell you a new Galfer front S.S. line for $40. E for details livia@lisco.com Mark P.S. That is a deal.
Hey mark is that Galfer for an RM or DRZ? If its for the RM and Phile doesn't want it I'll take it. mttgrmn@aol.com thanks! :)
I wanted to do the same thing, but I decided to bleed it first to see if it would help. Now I can nose wheelie anywhere, anytime. You would not believe the air that came out of the bike when it was brand new. It was all stuck in the master cylinder.
Mark,
Just e-mailed you, I'll take it.
  • Similar Content
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
