yz125 connecting rod getting stuck HELP!
just got my crank back from rebuild installed it with new bearings then closed the case and then i put a new piston and cylinder on. The connecting rods bottom end part seems to be getting caught up in the from of the cases. any suggestions on what to do. also i noticed the pistons front exhaust arrow is not perfectly straight. bad crank rebuild? or did i do something else wrong.
did you get a new rod, or use the old one with new bearings?? could be worn bad, or bad crank job. it happens. in some cars the rod is posed to face one way only, don't know if bike do that too.. never seen an arrow not point straight, something ain't right.....
somethings wrong take it back to the shop and get refund or fixed.
all new bearing and rod. would a slight bend in the rod cause this or the fact that the dealership didnt true the crank.
i think most bike rods are the type of metal that will break before it bends. i think the problem has to be in the crank
well i just got a cheap new crank off ebay and am going to try that. this is my project bike and thats all i need for reassembly. if i get the same effect then i dont no what it maybe. ill post what happens when i get the other crank in.
They might have put a veshra rod on it which will cause it not to clear the cases when rotated. you will have to clearance the front and back of the cases to accommodate some aftermarket rods. Some of these rods are larger on the big end than the OEM part.
that's why I stick with OEM parts, I hate surprises.
Take a die grinder and remove some material from the cases.
ill wait for the other crank before i do that
I think you are smart not to mod anything until you find out what's hokey here. Your crank probably wasn't trued correctly.
When they fail to true it well, the rod bearings turn fine but everything binds up when you sandwich it in your new case bearings...
I hope you get it worked out. Sounds like a PITA :thumbsup:
There's nothing wrong with your crank, I've done thousands of cranks and this is common with some aftermarket rods.
I kinda ran into the same problem when I did my top end rebuild. Everything moved freely until I put any type of torque on the cylinder nuts. Turns out the cometic gasket was way thinner than the oem gasket and the crank was hitting the cylinder when tightened down. I just used double gaskets and I was fine.
ill check that also thanks for the idea. the gasket kit i have is cometic so ill check that out.
  • Similar Content
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
