Looks like I will be splitting the cases,advice please!
my 1980 yz100 has a cracked case from the chain comeing off.I tried to go the easy way and sell the bike,:thumbsup: but I cant get the $500 I was looking for.I know thats a little high but the engine only has maybe 2 hours on it top and bottom and everything else is new or looks new.this will be my first time splitting cases so any adivce would help.the crack is in the left side case.how far will I have to tear it down? will the crank have to come out?any special tools I will need?should I be scared?I do have a clymer manual that should be here tomorrow.
You will have to completly dissisamble the engine, to isolate the left case. There are several specal tools for the job but you can ussually make do without buy You will need a puller for the flywheel. Whats your plan for repair, replacement or welding. If the crack is minor you could fill it with metal epoxy without dissisambling.
Check out the video at Rocky Mountain ATV (linked here somewhere)....it shows you step by step how to crack the cases.
Best bet would be if you could borrow the case cracking puller tool they demonstrate. I have one, but unless you're north of Toronto, I can't help ya! ;-)
I agree with the suggestion to use the rocky mountain videos. There are three parts to the "bottom end rebuild" and it is a very helpful tutorial.
Part 1:
part 2:
part 3:
have you tried j.b weld?
Thanks for the advice,the video's are a great help.the crack is top to bottom,I tried jb weld but it only held up for one ride and the crack came back.I got a complete case off ebay.this will be my first time,Ive always wanted to tear one down.wish me luck!
splittin' those suckers is cake if you have the tool. A nice guy at the local shop will prob'ly let you use one if you bring the motor in your truck (just the bottom) and literally split and hand it back to him. If you have the right connections, you can take it home and borrow it for the day.
I would try to avoid buying the tool. A flywheel puller is a must if you don't have one/borrow one. that is a good tool to have kickin' around.
  • Similar Content
    • By 216AP
      I recently have been wanting to put a led light bar on my yz125 for night riding. I've looked everywhere for wiring diagrams and can't seem to find anything that makes sense to me. I purchased a 45watt stator from electrexworld and I have installed it but I can't figure out how to hook my light bar to it. There are two yellow wires that come out of the plug and I don't know what to do with them. Can anyone help me or provide me with a wiring diagram? PLEASE!
    • By MathiasJK
      Hi guys, I'm new here and bought a have 2001 a month ago and the engine is almost down in pieces, need the flywheel puller that's ordered and the parts needed for the rebound of the engine. I'm also ordering Haynes YZ manual as I think it will be a good buy for me.
      Anyway, the VIN strarts with CE08CE I think... on the back of my cylinder there where some mechanic had written with a marker pen -01 125. It seems like there have been a major failure before, as the head has small dents in it, and the cases are clearly not the same as the one with the VIN is much much smoother in the inlet and crank case.
      Engine VIN is E111E I think, or something very similar to that.
      It has a white Airbox and floating front brake, I've read on other threads here that that was a new thing for -01, is it?
      Fast help would be much appreciated so that I can order parts as soon as possible.
      BTW, here a rebuild with wiseco crank, all seals, new main bearings, new ring and all new  gaskets cost about 500$. Just the crank at Yamaha was 1,200$ at the local Yamaha centre so you all should count yourself as very lucky!
      Thanks for help! I'll post other threads soon as I'm at the beginning is going to post the cases for a smoother flow and have complete HGS system. I really would love to have a 144 but I guess that will cost me insane money as everything is more expensive here, and I also guess sending head n cylinder to the U.S. would cost way to much too... So I'll, be doing what I can on my own and that's the cases for better flow and matchporting it to the cylinder.
      I much appreciate any help! Thanks!
    • By faizakhtar125
      I've heard if you put VForce Reeds, properly jet your carb and clean the carb, change the exhaust pipe, clean the airbox and put a new air filter, and properly fix the shocks to match your weight, you can gain a ton of power?
    • By Allooushh
      Please help! I recently bought a Yz250f and have not been able to start it, it Has spark, but there are many issues with the carby which I wanna rule out before I leap into a rebuild, ( I want to avoid a rebuild if possible as I’m low on cash). The carby at the moment is a complete mess so the usual steps to fixing it might not work. So here’s the deal with the carb:
      - It’s leaking fuel from overflow ( really fast! ) and when I mean really fast, I mean it emptied my fuel tank in 2 mins.
      - It has a slow leak coming from somewhere under the float bowl
      - the air fuel screw is not adjusted correctly
      - I don’t know if the electrics work on it either
      - I don’t even know if it’s shooting fuel into the cylinder or not, as after kicking it a couple times and it’s not starting I remove the spark plug and it’s still dry. ( I tried putting fuel directly into cylinder from the spark plug hole but the bike still wouldn’t start)
      okay so I know it’s a lot but I’m not expecting anyone to answer every single question themselves. If each person could tackle whatever problem they know it would help heaps. Also just want to know what Order to fix things in as I can’t do air fuel until the bike is running and it won’t run unless I stop the leaking and get it to spray fuel into the cylinder. And buying a new carby is not an option ( I’ve got $40 to my name atm). Please help guys thanks.
