Trust the RaceTech Spring Rate Calculator?
I'm looking to do a simple suspension upgrade on my 2004 DRZ400S. According to the RaceTech spring rate calculator, the rear is sprung OK for my weight (165 + gear, oversize tank, DirtBagz+tailbag with crap in it, easy trail riding), but the front should be 0.48 (0.44 is stock).
I've read a bunch of posts and get the impression that RaceTech tends to suggest a rather firm spring rate. John C. (mod) updated a local guys DRZ and only used 0.46s. The other guy outweighs me by 50 pounds.
So I'm on the fence regarding spring rate. Should I trust RaceTech and get the 0.48s or use the 0.46s for a plusher ride. BTW, my use is 50/50 street versus dirt with the dirt being pretty mellow.
I would get the .48 and put ONE in with a stock spring. That will give you .46 rate. Then try both .48. If you are puting a bigger tank on I suspect the .48 will be better?
Those bikes come grossly undersprung on the forks. ALL the 450 MX bikes come with .46-.49 STOCK and they weigh about 70lbs less than the DRZ!
I'm wondering about the same thing. I have an IMS 3.2 Gal tank. That's only half a gallon more than stock (roughly). With fuel weighing about 7lbs per gallon, it hardly seems worthwhile to select the "oversize gas tank" option. Not to mention the plastic tank weighs less than the stock metal tank.
I'm about 210 lbs in my birthday suit. Gotta figure at least 30lbs additional for boots, gear and a Camelback. I ride mostly trails.
Race Tech suggests .486 (.48) for the front and 5.7 for the rear (based on 210 lbs w/o gear). The stock rear is 5.5. Will the 5.7 make that much of a difference?
Anyone near my weight want to "weigh in" on DRZ springs :thumbsup:
Tipsy
your fuel is carried high so you should add it on the generator.0.2 does make a decent difference on spring rate.
I don't claim to have all of the answers but the way I see it, a pound of lead weighs the same as a pound of feathers.
If my IMS tank weighs a few pounds less than the stock tank and it holds a few pounds more fuel, I don't see what relevance there is in selecting "oversize gas tank" option in the calculator.
Tipsy
it also depends on how high the fuel is carried, as higher up gives more leaverage over the forks.
Sounds awful stiff. I used .42 kg fork springs on my KTM 525EXC and loved them. I weigh 180. Bike was used for offroad racing. I tried .44kg springs and them bike was better in sand whoops but really sucked in corners and elsewhere. Wouldn't setup for the corner.
Dwight
Great idea because the spring calculators have generalized assumptions that may not fit your type of riding and style.
