Crank gear key help......
Ok, bike started making a little noise Saturday while riding, so for giggles, I checked the valve clearance, needed to be done anyway. Then I pulled the clutch out to see if maybe the key and gear were loose, is there anyway to tell without taking the complete side cover off of the case? Or do I have to pull it all down and pull the gear off? The gear doesn't seem to move or have any play but it is not possible to see the ballancer(?) gear with the cover and other stuff still on. This motor was replaced last Sept. and I am thinking this is what happened to it the first time. What are the possibilities of Yamaha puting an '01 crank in it when they rebuilt it? As usual, thanks for any help given.
…is there anyway to tell without taking the complete side cover off of the case?
Not really. I suppose you could take off the mag cover and flywheel and check for play in the counter balancer shaft from that side…
IMO the only way to be sure is take off the side cover (not just the clutch cover) and see if there is any play in the counter balancer shaft. It should not rotate at all unless the crank moves also.
You mean your dealer? I have no idea. See if they charged you for a counter balancer drive gear, because that would need to be changed also if they put a newer crank half in. It should be about a 30 minute job to find out for yourself (remove clutch and main gear).
Hope this helps.
You've got to pull the right side case to check the CB-key. Just pulling the clutch cover will tell you nothing. All the repair can be done by just pulling the right cover. I had to replace the right side of the crank after a failure. I'd recommend this to anyone who has to repair the cb-key more than three times. The gears begin to wear. The 2001 parts fit perfectly, and they are splined. When you repair the key, do a search first, but everyone who has repaired it has had better luck making thier own key and fitting it a bit long and tight. Make sure you tighten the nuts on those gears well and use a thread-locking compound. Good luck.
I second glens entire post.
I would doubt that the dealer would put the 01 parts in without a serious upcharge, or a specific request to do so.
If your key is going bad, its an easy fix really. Kind of expensive though, I think it cost me like 90 cents total. :)
One more question, I am down to the gears, everything is tight. Do I still need to buzz the crank nut off and look at the key and keyway or consider it tight from the feel of things?
Yep, I would. When you remove the cb-drive gear, look at the key. If there is any mark at all you should replace it. Mine barely had any wear on the keys that I replaced, but oooh the racket they produced. Remember, the torque force on that gear when you are wicking the throttle is way more than you could reproduce just by "feeling" for play in the gear. Hope this helps.
Thanks for the insight, I did pull the gear off and there are wear marks on the key. TT comes through again! Now, about this key, how do I go about finding the right size key stock and where? Is there a common size everyone has used or are they all different? I guess it depends on how much your gear is worn huh?
If you can find a decent industrial hardware store, if they dont carry it, you can order a piece of 5mm key stock. Dont bother with the Yamaha part. I think the created thier own alloy for the and some how counter acted the laws of nature and made a metal softer than lead for thier key :)
Anyway, get a piece of 5mm key stock, and make it as long as you can without it being longer than the gear is deep. Remember the broach on the crank tapers up to, so your key cant be in that area either. If your 5mm key doesnt want to fit, you can fit it by GENTLEY sanding it with 6oo wetordry sand paper on a piece of glass. You use the glass because its the flatest thing around, unless you have a surface block laying about or and end mill in your pocket. :D
Thank you very much guys.
I can only get them in packs of 5, 5mm square by 12 inches long. Anyone need any extra?
  • Similar Content
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
    • By Goof331
      Does anyone know if there is any differences between the 2 radiators? Will the yz450fx radiator bolt on a yz450f? What I am wanting to do is wire up a fan to my 2016 yz450f. I know how I am going to do it I just don’t want to use a “universal” fan kit. What I would like to do is get a 450fx radiator and the direct bolt on Trail Tech fan for that radiator to have a good clean look.
