spark arrestor
Hi. Is there a way to seperate the spark arrestor from the chrome end cap without breaking it? I noticed there are 3 spot welds where the cap and the arrestor join. I want to be able to refit the arrestor when i go to sell the bike. Im actually trying to make the bike louder so i can hear it over other bikes and it looks a lot better with the chrome cap installed. 01 xr250. Cheers
Leave the spark arrestor alone. Most of us are trying to quiet the bikes down while keeping the power. You want to make noise.
Get an aftermarket exhaust like Pro-Circuit T4 or FMF T-Max.
You can get a aftermarket diffuser for the bike also. Just take the tiny holed end cap off. The spark Arrestor does little for the noise level anyway. If you relieve the back pressure too much you will lean the bike out to where you will have problems with running and overheating. Plan on rejetting. Contact Geoff Ballard at Ballard's XR's Only there in Oz.
Cher'o,
Dwight
I have to agree with Dwight. Though I would say, if you want an obnoxiously loud bike, get a Harley.
Also, I keep reading about fires in Australia. With all of the fires, tampering with a spark arrestor would be the last thing I would do.
You can look at us as a bunch of grumpy old guys in America or long time motorcycle riders who have watched numerous riding areas get closed down due to loud motorcycles.
  • Similar Content
    • By libsead
      Guy's,  I have an 1997 Honda XR400R and I need to do the front forks.  I'm a big guy 6'4" 375lbs.  So far I haven't been able to find a setup for a big guy. Any suggestions besides losing a lot of weight. :-)
    • By Scat Adams
      OEM Rear fender from an XR400. Fender includes Baja Design tail light as well.
      $20 plus shipping, located in San Diego.
    • By Alex John Blanch
      Went riding on Christmas Eve  everything was working fine went through some mud and slipped dropped my bike tried to kick start it and the kick start went limp pushed it back up got compression again  kicked it over a bunch of times started to run again  rode it for the rest of the ride with no problems then on the way back on the road I gave it fill throttle  and it died hasn't started  since and now has little compression. Replaced the spark plug and changed the oil and filter and adjusted the valves but still very little Compression and won't start.
      Any ideas??  Would greatly appreciate
    • By Ricky Bobby 21074
      I have a 1986 xr250r, I'm interested in converting the rear drum brake wheel assembly to a rear disc brake system. Has anyone done this, and can you tell me what application parts will get the job done. thanks
