FRT SM610 Wheel / TE510
Hi,
I got a set of 17in SM610 wheels from GP Cycles.
I tried swapping my frt rotor from my 08TE and the screw holes are larger, is this a common issue? Will I need a different rotor too? I'll Call GP Tuesday, just looking for an answer sooner.
Yep, standard issue. The SM hub uses larger rotor bolts than the TE hub. Easy enough to drill out your TE rotor holes to fit the larger SM bolts. Good luck, and enjoy the SM wheels, I sure love mine!
will my rotors still work on my TE after drilled out?
No. I drilled out mine and that rotor stays permanently with the sumo wheel now.
  • Similar Content
    • By birdland101
      Restored 1974 honda xr75 original motor and frame podercoated frame runs, looks, shifts, stops good. top end rebuild many new parts most all honda. email birdland101@hotmail.com. May trade for decent riding lawn mower.
    • By Bryan Bosch
      Anyone going? We'll be there w/ ThumperTalk Contributing Editor @Scott Meshey 141 Dealer ship said they'd be kicking things off 4:30 to 5pm tonight. Hope some of you can make it.
    • By 1madgerman
      Hi Thumpertalkers,
      Just making a thread where I can share my videos as I make them.
      I will start the post with posting a few old ones until I get some more new ones.
      I'm no expert by any means just have fun making and sharing videos!
      Thanks lars
    • By 305hestbeck
      So I just sold my bike 2017 TC250 with only 17 hours on it. When it left it was in brand new condition. But 2 days later the engine cases were being split.
      Turns out the Idler gear had snapped off during the new owner’s first ride. Of course I am not paying for the fix as one it is clearly a manufacturing defect. I told him If needed I would help by me claiming it as warranty issue.
      Anyways I did some research and discovered that the KTM/Husky expected a 6x12 to hold the idler gear sys together on 2017.
      Well this seems to be an issue and KTM did fix it for the 2018 models. They actually updated the whole Idler gear sys, but if you still have a 2017 2 stroke the fix before it happens which it could on the first kick would be to replace the bolt with a 6x20.
      You will have to tap the hole for more treads. Actually the 2018 engine case was also updated for this and that’s all they did.
      I own a 2018 TX300 now. One reason why I looked into it.
      Just thought I would share.
