Heat Shield Fabrication??
Hey all, I bought a full T4 exhaust for my 00 XRR and now when ever i stand for long periods of time, it will bur my pants. I don't really mind, but when I ride to work, my scrubs get holes in them very fast. It's not the headers I am having troubles with, but the pipe that connects them to the can. Anyway, I was just wondering if you guys have had the same trouble, and if so, how you are coping. Thanks guys.
You might want to try some header wrap on that part of the pipe (or the whole header for that matter). It won't make it cold to the touch, but it'll probably bring the temperature down to the point where it won't burn holes in your pants. It doesn't cost much for a roll of it and you can pick it up at just about any automotive parts store.
I've seen that stuff before but never thought of it. How well do you think it would hold up? I get pretty dang crazy on mine, especially when chugging through deep water.
It holds up pretty well, just make sure that when you put it on you get it on there tight, and you keep it clean and dry when the bike isn't in use. A 25 ft roll doesn't cost much and should be enough to do that part of the pipe many times over if you feel the need to change it out fairly often.
Sweet, I'll give it a shot. Thanks Dog
No problem. :thumbsup:
Iv'e used the 2" black stuff from Summit racing.com.Have re-wraped it a couple times in three years. It last a lot longer if you paint it with hi-heat paint when your done.
  • Similar Content
    • By Motorius
      Can anyone tell me if a Showa rear shock off an XR650R would definitely fit an XR650L (mine is a 2008)?
      Thanks!
    • By Pcolamotorhead
      Parting out almost an entire bike. Frame is gone, CDI box, and Wheels, Gas Tank, Headlight & Front number plate. Complete unassembled engine with 9611 miles on it. 90 pounds of compression at cranking speed. According to hondaprokevin.com this is what it should have.  Checked the compression with 3 different gauges.   Valve clearance is good which indicates no cam or rocker arm wear. Oil did not look too bad that came out of it. Corbin seat, Super trap muffler, and just about all the other parts.  Shoot me a message with what you are looking for and I will be happy to take pics and send them to you along with a price. All items are buyer pays the shipping.  Also have some 1996 Honda XR600R parts. Engine cases, Electronics, Etc.  $850 for the motor and you pay shipping, Starter motor not included.
    • By Jeremy Evans
      I just bought a 2012 xr650l and it starts and runs great until about 4000 rpm give or take (I’m guessing) it feels like it spits and pukes. Also when releasing the throttle the exhaust pops and hiccups. I am calling the dealership to ask if they are willing to fix the problem as I just purchased from them yesterday but I am curious as to what the problem could be in case they do not offer to help for my “as is” purchase. I have read a couple other topics on here that talk about the vacuum lines being hooked up to an air cut diaphram but I don’t know what that is. The smog delete has been done on this bike as well as a slip on dg exhaust and the side cover has a bunch of holes drilled in it exposing the air filter. The battery has also been relocated. My question is what jetting should I have at 2000 feet? I am planning on opening up the carb to see what the idle jet and main jet are and if they were even changed from stock. Also if someone knows about the air cut being hooked up to vacuum and can supply pictures that would be very helpful. I know that the smog block off kits just plug the vacuum holes and the air cut usually gets disconnected. Thanks.
