Suspension Recommendations
Looking for some advice from Dwight (or anybody) for my 2006 450 EXC. I haven't raced in about 10 years, but plan on doing some Hare Scrambles in the spring. I would love to send it off and have it done, but can't afford the $$.
I weigh about 190 pounds without gear. I have noticed that it will pound my wrists when I am riding aggressive. I am assuming I need a heavier spring for the rear. What about the front? Also what about the spacers, oil and starting point setting for the front? Thanks for any help!
I just went through this same type of research, get the right spring, set the sag, take it from there ....
BTW there are good deals on used springs out there, .... shop around,... I've seen several for sale here and there check the forums !
I ride an 08' 505XC-F , I weigh 195lbs w/o gear the charts told me I needed a 8.1 (theoretically) .... I bought a WP 8.0 Straight Rate (used) for 50 $ .... I'm happry with the handling changes ! I'll work on the fine tuning for now
Seek the advice of the TT boys and / or a tuner for your specs front and back,... in my case the front springs (4.6) were OK for me !
Good Luck
Thanks Andrew. The 06's and 08's must be quite a bit different as I believe my stock rear is 8.0.
9.2 to 9.4 rear spring, 44 front springs. 06 shock is a good one. If the front is hammering you then reduce the comp by 4 clicks and ride, if it starts to bottom then add oil to prevent this. ou cab add equal amounts of oil thru the bleed holes, 1oz equals approx 10mm in height for oil measurement. For about $150 you can get some exchange front cartridges that will make it soft and progressive and still not bottom, I did this, front was good stock but is not better.
Thanks Mike. Any opinions on progressive versus straight rate? Who do you recommend for the front cartridges?
the system is designed for straight but many use prog, I use str. I used Lew for the cart and have used Javier also, both good work.
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
