Oil pressure & Temp Gauge
I want to put a electrical oil pressure & temp gauge on
my dr650.
I know the service manual shows a place to mount a sensor
but it is in the middle towards the bottom of the case.
Isnt this a bad place to put a sensor ?? ( can be broken off by rocks )
is there another place to place the sensor that you know of ???
That spot is well protected by the skid plate, I am going to use it when I finally get around to install my Touratech IMO computer.
There are alternatives, one would be a sensor ring around the spark plug (like the Vapor has) and there are also banjo bolts (used on oil line) that are threaded for sensors.
