Yoshimura exhaust ?
I am thinking about getting a yosh full exhaust I have an 08 yz250f yosh lists the 06-08 as same part# I know 07 & 08 are the same and 06 was different I dont want to get wrong part Why do you think it lists 06 as same part# as 07 and 08 Or if anyone know if it will fit,Thanks.
It will fit 06-08. The only difference between the 06 and the 07-08 was that the engine was rotated 2 degrees. This was such a small change that most aftermarket companies do not bother to make a separate header, as one header will still line up with both engine positions.
Thanks KJ I knew you would know the answer. Next time I will cut out the middle man and just Pm you.
