97 KX 250 needs torque
I ride my 97 kx 250 in some real nasty slow speed stuff and it never seems to have enough low speed power. I have the heaviest flywheel weight, Knarly pipe, running 12t front sprocket which limits my top speed to nothing and I am in search of the next add on. I always liked the kdx motors but I won't part with the kx because I love how it handles. Jetting is almost perfect for season, so I'm thinking reeds next. Which reeds give most torque? This bike is a rocket on top end. Ant other ideas? Thanks.
you need a hybrid
Yea, get a kx 125 roller and put a kdx 200 motor in it.
Just don't have the time or funds for a project like that.
More compression... More timing...
That's weird because those bikes are nothing but torque. What rear sprocket are your runing? When was the last time you did a top end and serviced the powervalve?
im confused, the 97 KX250 was bike of the year based on its low to mid power. i used stock gearing at the dunes with a paddle and never wanted more low end.
like jeekinz said how fresh is the top end??
Find a Radvalve and raise compression a little.
Top end was fresh when I bought it last summer. Has tons of compression. I think this bike was raced MX for a while and though it was treated and maintained well, I wonder if it was modified to have more top end. In 5 gear cruising along, if I roll the throttle it takes off like no other 2 stroke I've ridden. I raced my buddies KX450F and can smoke him through 5 gear, after that he blows by me. Maybe i'l change the reeds. Also, it came with 13/48 gearing. I'm running 12/48 now.
I run 13/50 and find that perfect and regularly use 1st & 2nd on the tight stuff - Mainly 2nd. 12/48 makes 2nd gear too high for the tight stuff so end up using mainly 1st which is too twitchy and if you try 2nd you are reving too low. Just mey experience.
I run v force reeds, Gnarly pipe, Shorty and 10oz FWW and all these things help.
+2 for the powervalve. If it is stuck open the low end will suffer. Can you pull the cover and see if it is operating?
i have to agree with the power valve theory, sounds like it may be stuck open.
Hate to dig up an old thread but I have my bike all apart for a repaint and figured I would look into the power valve and see if it was working. When I took off the side cover I noticed the pin on the arm coming from the bottom end was not in the slot as it supposed to be. This was keeping the powervalve from closing. Can't wait to get it back together and try it. You guys were right.
That means someone not familliar with Kawie's put the top end together. You can sneak it in by loosening the base nuts and repositioning. If you have the money, I would just put a new top end and gasket kit on her, service the powervalve at the same time. Then you're done with it.
The person you bought it from may have tried to compensate for that, so check the jets and ignition timing. It's probobly why he sold the bike. lol
You have major mechanical issues with your KX250.
I raced a brand new '97 KX250, and that engine was the pinnacle of brutal KX hp (bike was voted bike of the year by Dirt Bike mag. by virtue of shear HP alone). The fastest 250cc in '97 PERIOD... How about instead of all the zoot hp mods, doing a fresh top end rebuild?
If you read two replies up, you'll see I found the problem. The top end was done last summer before I bought it and that was when the powervalve arm was no lined up right. How do the 97's power stack up to the later 250 2strokes?
did you know that a 1997 kx 250 has almost but not quite twice the hp of a 1997 KDX 200? that ain't nothing man.I'll keep my low hp KDX 200 and hit treelimbs w/the best of 'em. hp has never meant a thing unless you are looking for speed,low end,mid range,hill climbing,drag racing 4 strokes,drag racing other 2 smokes,racing mx,racing enduros,racing hare scrambles,not racing at all but just riding around looking for sh-- to jump(that's what I do),and all that. so in other words,if you don't do any of the prior mentioned stuff,what good is hp?
Treelimb is rite buy a KDX if you want to ride the nasty tite stuff. I love mine it will go anywhere with out cluthing it all over. Sounds like you know alot more about bikes than I do but have you thought about using a torque ring?
hey clifty.don't get me wrong because i would love the huge hp. I would not know how to deal with it. The guys w/all that hp do and i guess they miss it.It BOGGLES my mind simply because of how my half as powerful(maybe not half due to my mods) still scares the hell out of me on ocassion and could not envision the hp of a modded kx250.
I like their need for more bike though.People claim I ride like an idiot and too fast.can't imagine having a bike w/even more output.I'd like to experience it once or twice though.
  • Similar Content
    • By Shawn658
      I am trying to find out if the water pumps for the KX250'S will interchange. Seems most parts from 96- 07 will. Can anybody help me out? My plan, put a Boyesen Supercooler for a "05" model on to my 99. Will this work? Any help is appreciated! Thanks
    • By Daniel Wolfe
      So i know my way around a crab pretty well and i'm very familiar with them i just can't seem to get the kawi dialed in it seems to have this unging/erratic rev thing going on when i pull in the clutch and i slow down so i'm looking for the correct carb adjustment for the bike it didn't seem to do it when it was warm out but now that it's in the 30's forties it's doing it my elevation here in upstate ny is 295' it's been around upper 30's lower 40's but i'd like to tune it so it's ready for summer because i don't ride it much in the cold so i'd like to tune it so it would be best in 70-90 degree weather since that's pretty common around here So could someone please help me out I need to know what the fuel to air mixture is needle position and proper jetting thank you
    • By Henry Nichols
      Okay guys, I have a 1997 kx250 frame and I wanna know(if even possible) if there are any 2 stroke engines besides the original that will Bolt onto the frame without any modifications.
    • By Alex Seprish
      Hey guys I have a 1991 kx125 and it needs a crank but you can not find em anywhere so i need a good cheap place to get it rebuilt if you guys know any place let me know thanks
    • By DirtBikeHead
      Beautifully restored 1996 Kawasaki KX250! Hard to come by them likes this... has a ton of nice upgrades, including:
      PC (pro circuit) linkage
      PC valved suspension for 190 lb rider
      Rare PC seat cover (brand new)
      PC pipe works pipe
      Acerbis 100% carbon silencer
      Emig Racing top triple clamp
      Gold DID chain (brand new)
      Tag oversized bars
      Aluminum skid plate, disc guard, caliper guard etc
      Eline carbon fiber pipe guard
      Upgraded radiators (brand new)
      295cc kit has 12 hours on it
      Throttle cable (brand new)
      Steahly flywheel weight
      Plus much more.....
      Bike was just completely rebuilt, fresh grease, new bearings, new fork seals & wipers, new fork fluid, rear shock just serviced too. Ready to ride, needs ABSOLUTELY nothing and performs amazing.
      Bill of sale, have recent receipts
      Cash only
