Whats the Better and Difference Mikuni and Keihin
i wanna know the difference and which one would be better for my ttr125 stock with a Wiseco Hi Compression on the way what at the differences and witch are better
first off if your taking it down......go with a bbr or hot cams.....cam while you have it down.........you can use the stock carb for a while......and would get better performance for the buck than changing the piston and carb without the cam. i thing it would be closer to a big bore performance if a cam was added along with your piston........the cam gives you the ability to make better use of a bigger carb.......i like the 24 mm keihin round slide for a stock bore.....ttr not saying they are better........its a good size and choice for your application.
