CRF 450R stall/hard to start in bush
Been using a CRF 450R o6, in the bush and have been struggling to get it re-started on steep hill climbs. It seems easy to stall and is running standard gearing , low enough to climb something of a good ascent.
This is the first 4 stroke motocrosser I have used as enduro mount, had an easier time on 250 strokers even on some gnarly climbs.
I am thinking there maybe something to do with timing (possibly altering?) and it not liking the extra engine heat produced at slow speed first gear hill climbs.
If this sounds familiar or someone has experience with this, would you please advise me, much appreciated. Thanks
I'm thinking maybe a FWW would help you out? I'm probably going to add some flywheel weight to my 450R but I'm afraid to tamper with the bone stock motor because it runs so well as is.
this may be good solution to stalling but wondering about restarting on the hills. Have you encountered this also, this bike seems to start ok under normal conditions.
I have the same problem with my 06.:thumbsup:
So if I'm understanding correctly you are having trouble starting the bike after a stall when it is pointed uphill and the motor is hot? I have encountered this same issue on every 4 stroke I've ever ridden and each has its own little ritual to get it to fire. I don't have but a few hours on my 450R and those few times I've stalled it fires right up with the hot start pulled tight and a couple of kicks. I take my hand off the throttle when kicking any 4 stroke hot or cold normally. If the motor is super hot sometimes pulling the hot start and holding the throttle wide open will light it off. A FWW will also make it start a little easier. Another thing I do that drives some people crazy is keep the idle high. Helps prevent stalls and makes hot starting easier IMHO. Let us know what you figure out! I'm all ears:thumbsup:
You might also want to consider going changing your gearing. Some of the woods guys can correct me here if I am wrong but you should be abot to go to a 50t rear and just run all the hills in 2nd. It will suck for top end in mx but if you are primarily woods then you probably wont miss that top end.
Thanks so much guys for your pointers, I'd say all of those will be of use to me this weekend, got a 3 day ride hapening in the Victorian bush here down under.
I didn't get too adventurous with the hot start button so will apply that, the fast idle trick I did give a bit of a go, bit of a roller coaster ride on some Big Down Hills.
Am keen to try some different gearing, though a lot of our riding is a mixed bag, tight single track and sweeping more open faster stuff, may have to do some quick cog swap overs.
The bike has around 17 hrs on it, just wondering when you guys may have looked into your 1st valve adjustment on your 450's?
Thanks again for your help.
Btw, we had a blast driving through Arizona and Tenesse in 2005, among other states, but 5,1/2 weeks only allows so much time to cover so many miles.
Checking the valves is really easy so you will want to check them for sure. As far as adjusting them, it should be a while if you stay on top of your mainenance (oil and air filter). The head was changed in 06 so the valve seats are harder and tend to wear slower. I would definitely at least check them so you have a reference and date so you can see when they start to go out of spec.
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
    • By Mxer59
      I have a brand new Barnett Extra plate setup still in the box. It replaces the judder spring with a regular fiber. My old clutch had a judder spring break which wiped out the stock clutch. I was in a bind ordered this kit but it ended up coming 2 days later then it was suppose too. So now I don’t need it asking $180 SHIPPED
      —“Complete Extra Plate Kit- consists of 8 Kevlar friction plates, 7 tempered steel plates and a set of springs. Provides maximum clutch capacity.”—
