cr125
I really want to sell my crf230 and get a cr125 but I've never had a two srtoke and I was wondering how often and how much mateinance is required for a 125. Any other info. on 125's would be great thanks.
they are great bikes. just got to learn how to stayin the powerband. it will make you a better rider. I you ride woods I would suggest a 9oz flywheel wieght. the maintenance isn't big, just change trans oil and run a good 2t oil. I run amsoil dominator 45to1. maybe a topend every other year dependy on how hard you ride and how much you ride. but you can get a kit at motosport.com for $129 and do it yourself:thumbsup:
a 125 engine wise would be easier to work on that your 230 because its a 2t and there is a lot less moving parts. only thing is that you need to replace a top end depending on how hard you ride, if you ride real soft you could probably get 50 hours out of your bike if yea ride hard do it at like 25-30
and obviously change the oil etc.... good luck!
thanks
what is the best year model for a cr125? 07 because its the newest or an early year?
230's are garbage. my uncle has two of them and i bottomed out the suspension on that thing off of a 5 jump.
i would get you a 98-01. when you get to 02 and up they kinda went backwards in the motorbuilding department and your not gonna get as strong of a motor as the older ones.
im definatly tired of mine. its been very reliable but after i had been ridin it for a few months I got bored of it. thanks for the help.
not to mention they are so damn slow!!!!!!!!!!!!!!!
you can get an 01 125 cheap too!
The 05-07 are supposed to be the best 125's.
I ride an '04 and I love it.
i kinda want an 07 just because there the newest but all I really care about is reliability and that it wouldnt have over the top matanience. Plus I'm hoping that an 07 can stand a chance against my friends 03 yz250f
An '07 itself won't beat your friend, remember that its more the rider, not just the bike.:thumbsup:
I agree.... if you dont stay within the powerband, you will stall the bike. It took me a couple rides to get used to the cr125....On my 125, there was no bottom end so you had to stay with in the R s.... on a 2 stroke, you have to maintain it a little more than a 4 stroke so just do a tune up every 2 rides and clean the airbox for maximum air-flow. For the pre-mix, i ran 40:1 and it ran cool all day. And you have to replace the top-end every 20-25 hrs.
thanks for your comments, I ride my freinds 06 rm85l sometimes(he got his brother yzf), ands I love it. Its way small but I rele like it, but your totaly right about the powerband. That thing can move for a little bike. I cant wait to ride a 125.
As far as reliability goes I don't think you'll have problems with any of the CR's as long as you maintain it properly and run a good oil mix. For my CR the most extensive work it has needed was a re-jetting and an oil change.
As far as keeping up with your friend's bike, a more fitting question is whether you can keep up with your friend on any bike. Rider skill will out-do a few more HP any day :thumbsup:
  • Similar Content
    • By Yamaha0963
      So I started my bike today and a lot of smoke came out from where the air boots  clamp on the carb (both sides) where the air boot meets the air box, and where the pipe meets the cylinder. I can also hear a leak but I am not sure from where. It also bogs. What could this be??! I started it yesterday and it ran fine, no leaks, no smoking, bike revved up good and everything.
      i should point out that I did take the carb off, disconnected the air boot from the air box. I put some grease on the air boot so it would seal against the air box when I put it back together, it was a pain in the a$$ installing the carb but I made sure that the air boots clamp all around the carburetor. After I was done I started it and it was completely fine, no issues.
      UPDATE:
      well it turns out that I still had the exhaust plug....(Facepalm) should I be concerned that the air found a way out??? If air can find a way out then air with dust can find a way in. Also, could this mean bad reed valves?? It has the vforce reeds but the cage is grey with purple lettering (not the normal black cage with yellow lettering)
      thanks
    • By Yamaha0963
      Hey so I have a Cr250r with a few mods
      -PC pipe
      -Vforce reeds
      -Keihin PWK carb
      I was wondering what race gas I should use, I am a weekend rider and I do not race or anything like that, I just want to use some race gas on my bike so it runs better. (Don't want to run straight up pump gas)   I am looking to mix with 93 pump gas because running straight up race gas is too expensive for me.  What gas would be good for me that is not too expensive. Thanks!
    • By Yamaha0963
      Hey guys, so I recently bought a 02 cr250r on Craigslist.  The guy claims it has a new oem cylinder and piston with 30hrs and a new crank with 60hrs.  The bike also has a PC pipe, vforce reeds, keihin pwk.
      Now my question is are they so easy to start?! My last bike was a yz250f and it had quite a bit of resistance when going through the compression kick and I got used to it.  When I went to start the cr250 I went through the compression kick out of habit and notice that the kick starter would drop under the wait of my leg and it was awkward for me as I was used to starting a 4t.  The bike started first kick cold with choke on and after warming it up it still started first kick.  Is it normal for the kick starter to drop under the weight of my leg or does it have low compression? Like I said it start first kick very easily.  The guy had 50/50 race gas and 93 pump gas at 40:1 (don't know about the premix) in the tank but I will be running 93 pump gas with stabil at 40:1 with Maxima super M (can't afford race gas) when I need to refill.  I will update when I start running my gas and see if it still starts the same. Thanks!
    • By Roman Krzyzanowski
      I have a 2000 Cr125r and I’m in the middle of rebuilding it I just put a new crank and new bearings and all new gaskets so far. I haven’t made it to the top end honestly I’m kinda stuck at this point I &%$#@!ed up and didn’t take pictures while taking it apart mistake on my end because I can’t even find any pictures or anything on it now. I already put the cases back together I’m now on the shift brake pause side I was wondering if anyone could help me with a few pictures of that side of the motor if someone had some? Or send me a link of a diagram of how it’s supposed to be and look. this is the only part I’m stuck on it’s pretty tricky but after that i just got the top end I really appreciate any advice or any pictures y’all come up with or diagram EVERYTHING helps I’m kinda dead in the water at this point ..
    • By 870
      I have a 2005 cr125 new to me. I had millennium tech replate cylinder and supply new piston. I replaced crank bearings and now it won't hit power ban. It feels like a 4 stroke bouncing off rev limiter. It is also putting a lot of black spooge out of exhaust i mean a lot. The plug is black. I cleaned carb and adjusted floats. I also repacked silencer. I noticed the carb leaking gas out overflow the other day. I suspect it is running really rich. I have a brand new pwk from Jd jetting I'm going to try out. I also did a leakdown test and it held. I also am not 100% sure the power valve is set up right. The manual doesn't go into great detail about this. But it seems like there is only one way to put it back together. I have the engine out I'm going to do another leakdown test and double check my power valve and put it back together with this pwk. Any other thoughts out there?
