2002 XR/CRF 80 - Rear Tire
My son and I just bought his first bike this weekend and this forum will be a great help! We need to replace the worn rear stock tire (IRC 3.6 X 14) on the bike. We are looking at the Dunlop 756 90/100 X 14 as a replacement. Will we have any trouble with rubbing or fitment? Thanks.
my dad and i didn't have a tire tool thing, so we were stuck with screw drivers and chizles to get the tires off and on. it was one somebiotch.
I installed the same size on my daughters 2003 XR80. Only I used a Michelin Starcross MH3 90/100X14. It fits great and hooks up in the dirt really nice. The Michelin is about twice as heavy built as that IRC it comes with. It will hold up well and can be turned around for better traction down the road. Hope this helps.:thumbsup:
The Michelin Starcross looks like a good option for a rear tire as well. I was a bit concerned about the tire diameter of the 90/100 size increase and any potential rubbing on the front of the swingarm notch. What replacement tire did you end up using on your daughters front? I have read some posts about swapping the stock front wheel for a 17" front off an early 80's model CR80 for more front tire options.
I have the 756 on my 80. It did rub a little on the plastic mud flap when it was new due to a taller profile than stock, but after some chain stretch and tire wear its fine. It might be a tight squeeze inside the swingarm so make sure the wheel is trued up good and don't trust the hash marks on the axle.
On the front of the 80 there are not many choices. I looked all over for a front tire, and ended up going to Honda for the original IRC. It's not a bad tire, but it is lighter built then say a big name brand. I think a saw someware that you could put the front forks and wheel assy of a XR/CRF 100 on the bike to have a ton more tire choices. I think the forks will slide rite into the tripel tree. You might have to look for the tread to confirm the fork and tire combo. :thumbsup:
Thanks Guys!
Since our bike is a 2002, the chain has probably stretched from it's stock position, so the taller profile of the 90/100X14 rear should just make the fit. We mainly ride in softer dirt and trail (not much hardpack) so the 756 seemed to fit our terrain the best.
We'll keep running the stock IRC front for now and then determine if it is worth swapping fork legs or tire sizes down the road.
I put a set of Cheng Shin's on our 80, and have to say I am very impressed with them-they don't wear, they have good traction, and the price can't be beat.
Same with me
We ended up going with the rear Dunlop 756 90/100 X 14. It looks great, fits just fine, and provides impressive traction. We got the old tire off the rim and the new tire mounted using 3 tire levers, but after all of the time and effort that we spent mounting the new rear tire, I believe it would have been worth paying the local shop to do it.
I was mistaken...our 80 has Kenda Trakmaster's on it. :smirk:
But my impression is still the same, just mixed up what bike has what tires. :thinking:
  • Similar Content
    • By Tanker01
      Wanting to buy a TK link for my '89 XR100R. I have looked on the internet high and low for a used one so I don't have to shell out a ton of cash for a new one. If someone could help me out or point me in the right direction it would be greatly appreciated.
    • By Tanker01
      So I just picked up a 1989 XR100R in awesome shape. I plan to use this as my pitbike/parts getter. I have done some looking around at cool mods people do to these bikes and the aussie lift has come up multiple times. I fully understand how the lift is done but I haven't seen anyone say how long it lasts or if it breaks eventually. Obviously the longevity of the lift mostly depends on the quality of the welds, but are there any inherent risks that come with doing this to the bike? I honestly just think it makes it look better and I also plan to put the front headlight and plate from an XR600R on it as well as a tool bag and a few other things, so my main goal is to make it look like a baby 600. I have had these bikes before and I love how they ride and how reliable they are, I'm just worried the aussie lift may cause me issues in the future. I do not plan to put different shocks on the bike and will not max out the rear lift as to not make the bike super squirrley or twitchy. Any insight would be appreciated and if anyone has documented the process of how they did their lift I would love to take a look!
      (For those who do not know what an Aussie lift is: It is essentially relocating the bottom shock link mount slightly higher [most say no more than 11mm] so that the bike sits higher in the rear)
      I will post pics of my bike as soon as I get a chance for those who would like to see.
    • By _RaStA_RoCkEt_
      Howdy.
      Got myself a CA-Plated '90 XR100R, which is awesome. Used as my little slam-pig. Fantastic bike.
      ANYHOW; Just raised the front end with some 03' CR85R forks, which was a swap from the 80's disc-brake 19' KX80 forks I used to have on there.
      (The KX front end wil lbe up for sale soon, btw)
      Just wanted to ask the best possible way to go about raising my rear suspension, and it seems like users have gone 3 ways;
      1) Cut some 7/8 or 3/4 steel plate into spacers and use a longer bolt in the linkage to extend the travel. (Easiest)
      See Link (1)
      2) 'Aussie Mod/Lift' the rear end by cutting and re-welding the linkage mounts higher on the bottom of the frame (Mid-Difficulty) (thank SoCalXR, et-al.)
      See Link (2)
      3) Modify an existing swinger from some other bike, or even a whole new frame (CR85R? / KLX110? / SX65?) to fit, and then running linkless. (thanks SettinTrendz, et-al.)
      See Link (3)
      What do you reckon the best REAR END SUSPENSION LIFT OPTION for a play-bike/Minimoto?
      I'm 145lbs, 6ft tall. (ya, string bean) and before these mods, was riding the bike pretty much as hard as I could. I want something that'll hold up to the abuses of a full size human railing on it off road at the OHV or in the city.
      Thanks ya'll.
    • By Avorocks
      Hey everyone, new member here.
      I recently traded my 2001 Honda 250EX for a 1985 XR200R. The bike is tight all around and looks like it wasn't used much in its life. However, there is a noise coming from the engine that's not from the crank. It's up in the head somewhere. I adjusted the vales and started the bike up, only to hear a slightly quieter noise which led my father and I to believe that it's the Cam chain. If the bike ends up needing one, where can I find an aftermarket chain? I've checked eBay, xrsonly, and the normal part sites and I am not able to find anyone who has a chain in stock. I called my local dealer and they said they could get one for $70, but I just think that I can find it online for cheaper. It doesn't have to be OEM.
      Thanks
    • By Tbahr
      Guy's, After cleaning carb. When running at idle I'm getting a surge. I can lean the bike to the right & the idle decreases. Leaned left it increases. This is after cleaning the carb. Throttle is not binding, cable is routed properly, slide is in properly, no timing issues, no valve issues, filter is clean, fuel is new, spark is good, it runs good, plug is a touch on the rich side. My thought is float level off? See a video of this phenomenon at https://youtu.be/K9p4UFtbA4o
