Oil and Gas Question
I have received mixed advice on Transmission oil. So I am asking you guys. Are their differences between the synthetic/non synthetic oils sold by the manufacturers (Yamalube, Pro Honda) and the major brand oils (Pennzoil, Valvoline, etc). I would believe that using a high grade synthetic (Racing 20/50) and regular oil changes would do just fine.
Also in the jet ski world, in is common practice to mix aviation fuel with premium to get a cost effective high octane gas. Is there a problem with this practice for YZ400/426?
Thanks
Regarding oil - there are many opinions on this issue.
Here are the things people agree on:
(1) Change it often
(2) Don't use an oil labeled "Energy Conserving" on the API donut
(3) Synthetic is OK
Personally I have used automotive Mobil 1 15-50 for over a year. I used to change it every other ride but now I change it every third ride. I clean/inspect the oil filter every other oil change.
I think using a high quality oil and changing it often will be just fine.
I have no opinion on race gas since I just started using it myself (not diluted).
I run Valvoline 20-50 and change the oil every 3 rides and inspect the filter every other also. With the fuel, I run a mix of 110 and 93. I've used this combo for quite a while and have had nothing but good effects from it (nice burn and power)
Av gas is and never was designed for auto or motorcycle engines. The cetane rating (the rate at which fuel vaparizes in the combustion chamber) of av gas is designed for altitude at elevated temperatures, airplanes heat the fuel before it enters the carb to prevent icing. Mixing av gas with pump gas is an OLD racing trick that did not work then and does not work now. With the availability of quality race fuel or even just quality pump gas(sunoco 93 works great in my 426) mixing is not nessesary. It will actuall raise your octane rating but will probably cost you power since a fair amount of the av gas may not even burn on each cycle.
You make a good arguement and further are making me question my use of AV gas. Years ago I had a boat motor mechanic rant and rave about running AV gas in boat motors. Not so much an octane boost he was hyped about but the cleanliness of the fuel. Claimed AV gas didn't have the laquering properties associated with the detergents in automotive fuels. Also thought it did not 'go bad' as quickly and if left sitting in the carb would not leave a sticky mess if it evaporated.
Long and short of it I've been driving to the airport for the last 10+ years paying extra to burn up that 'special' fuel in all my small engines: lawn mower, weed whacker, chainsaw, pressure washer, hedge clipper, both boat motors and of course my 426. In fact I've never run regular gas in any of these.
That drive to the airport has gotten real old. Maybe it's time I revisit this issue. Has car gas gotten cleaner in the last 10 years? BTW-my car/truck are diesel so I wouldn't know. Or have I been following the rant of a lunie? Stuff runs great, never had any problems with it.
Av gas does not go bad as fast as pump gas, that is true. I've read that it is formulated for 30,000ft, and is not the hot ticket for cars or MX bikes. A bottle of Sta-bil from Walmart is a lot cheaper than AV-gas too. :)
In addition to still having lead in it, blue 100LL, Av-Gas also has other additives that can damage seals and such that are not made for aircraft engines. I just use Chevron Super or Mobil Premium; the Mobil has more detergent in it. The bikes run perfect, no jetting or plug fouling problems.
As far as oil goes I have some bikes using moto specific Mobil 1 MX4T full synthetic and Castrol ActEvo 10-40 synthetic. I don't use auto oils in my bikes. Coincidentally, I am also one of the guys who has not had clutch problems with the YZ450.
Hope that helps,
Joe
Funny you have good luck with Mobil gas. When I use Mobil in my 426 it runs great bug needs a new plug each new day (won't start). Any other brand I've tried is OK. Maybe the Mobil near me buys cheapo gas somewhere? Or better yet, maybe the 450 is better with plugs! :)
  • Similar Content
    • By BDTRENT
      Selling an FMF Power Core 4 exhaust system off my 450FX. Exhaust has 80 hours and is 100% functional. This will also fit the 14-15 YZ450F and 16-18 Wr450F. If needed I can also include new muffler packing although it does not need it.
    • By Woody Oakson
      I have a 2008 YZ450F with a stock header pipe and Pro Circuit T-4 Slip-On Exhaust. I'm 99% sure the slip on is shot because its loud as hell and when I take it off and shake it it rattles. I would repack it but the screws are all stripped ect.
      Anyways I've gone over the carb multiple times and I've got it running pretty well. The only issue I have with the bike is that it sputters and pops around 1/2 throttle when I hold it there. When I give it full throttle from any RPM it runs great or when I give it about 3/4 throttle it spins up like a top to redline.
      Initially the popping and sputtering was way worse I made the situation better by moving the pilot jet up in a few sizes from a 45 (stock) to a 62. The issue has gotten way better since then but I'm not super sure what to do from here. Should I keep moving my pilot jet up in size because that's a pretty large jump right? I tried changing my needle clip position but that didn't help much if anything it just made starting it worse and little to no impact on the ride.
      Any input on this would be helpful. I don't want to buy other slip on. Also as for the rest of the carb I'm very sure everything else in it is what it needs to be at. I've replaced all the gaskets and O-rings cleaned all the jets, valve holes ect. fixed the accelerator pump timing. I just thinks its strange that my pilot jet size is going so far from the stock 45, but all symptoms point to the bike running lean.
    • By Haydenbaha
      Hi I was wondering if y’all have been using a 450 on your YZ250F?
    • By RockerYZWR
      Excel Takasago 17x3 front and 17x5 rear supermoto wheels with Metzler M3 tires in very lightly used condition. Less than 200 miles total on the setup. Warp 9 spokes. Rear has a Talon hub with 45T Sunstar steel sprocket and OEM rear disc, and front has a polished OEM Yamaha WR450F hub (for the stock speedometer), with a Motomaster 320mm disc. Included is a DID gold o-ring chain, 14T front sprocket, and front brake caliper adapter for a truly turn key setup. Everything is in excellent condition, not a single scratch on these wheels. Came off my '11 WR450F, but will fit many different Yamahas with 20mm front and 22mm rear axles. Asking $1400 plus shipping.
      **Will be driving up near Atlanta, then to northern Louisiana, OKC, and down through Dallas and Houston, TX soon -- can meet or deliver if in the area (Aug 31-Sep 9)**
    • By YZ426fNC
      Hi I’m new on the forum and I was wondering if a 2001 Yamaha YZ426f clutch is interchangeable with a 2002 Yamaha YZ426f clutch thanks , Coleman
