Take a Look, I need a carb part...
Hey all you Mikuni BSR36/DRZ 400 "S" guys I need a carb bowl.
When I started taking my carb apart to do the mods to it I couldn't
get the drain screw in the bowl open and it was rounding off bad.
I hooked the vice grips to it to remove it and it was EXTREMELY tight
all the way out, I ordered a new drain screw but upon a closer look
the threads are messed up in the bowl.
If someone has a parts carb that they could spare a bowl off of at a
reasonable price let me know, dang and I let a complete carb pass
last week for $20 in the classifieds.
I am kicking around doing a rethread but the standard screw has the
cone machined onto the end to plug the hole, maybe I'll use a small
ball bearing or a piece of gasket material held in by a set screw to plug
the hole.
you can search on ebay for a new bowl or just retap the threads like suzuki sm nut 123 said. depends how bad they are
I didn't see anything on ebay and repairing the existing threads are
probably out of the question as they are really odd at 6mm x .75.
I'll probably end up with 1/4" x 28 threads.
