Chain size.
Hello all. I'm gearing down my 02 drzs, will the stock chain fit a 14/47 sprocket combo? And can anyone tell me on a 520x120 chain what the 520 and 120 stand for?
Thanks, Hossy.
I think you mean it the other way around. Stock DRZ-S is 15/44, going to 14/47 is adding 2 teeth total, thus moving the rear wheel forward more than stock. It will fit fine, that is what I run on my '03.
What's up Hossy?
Yeah, you stock chain will work. 14/47 is the gearing I run using the stock chain.
Later - Drew
Yeah, 14/47 works fine with the stock S chain.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
