Secrets to 1st kick starts in gear for HS?
My 02 CRF (with an 03 cam) fires 1st kick about 50% of the time, but I am tired of getting smoked off the line in the other half of my HS races. Besides making sure the FS is right, having a fresh plug, and making sure your decompression gap and valves are in spec, do you guys have any other secrets? Race gas, ignitions, etc?
I think until the piston, rings and cyclinder reach the operating temperature it will always smoke. Mine has smoked from day one when it is first fired up and goes away quickly after it warms up. I was told that with the single ring and single oil ring design, plus virtually no piston skirt to speak of that this smoking when cold, is normal. :)
go back to the 250F!
at our HS races, there are MORE crf's sitting on the line being kicked while the field is gone than any other single bike. i'm not kidding. at the season end race, i counted 5 of them in the A and B classes that didn't fire on kick one.
compared to the 1 yzf and 1 xr, that is pretty bad.
He meant getting "smoked off the line" as in still sitting there while evertone else is gone.
I raced one H-scramble with my 02 mike and it started out of gear 1st kick, I banged it in gear and was top 3 off the line. (vet expert)Bring a crate to the line and use that to rest your left foot on so it's easier to kick it over. Only thing is you need to have someone get the crate after you take off. (I don't use this method, but I've seen it done and it looks like it works good.)
Another trick would be a quick adjust clutch, take all the freeeplay out of it for the start and then flick it back so you have freeplay after the start.
SUnruh, obviously the guys down there on 450's don't know how to do a start at a H.S down there. I have yet to see one sitting there in the A or B class, maybe C class.
I'm rite with ya SUnruh. At the last moto-x here i counted 3 of em sitting at the gates in the 250 pro and ameture. IMO You were made for the blue one.
Get the bike ggod and warm, then kill the motor. Once the send off the the line two rows in front of you, start your bike, put it in gear and kill the motor. DO NOT let the clutch out, hold it in until your row is started. By holding the clutch in you keep the oil from bonding the clutch plates back together and creating stiction thus, creating drag when you try to fire it. Go out into your garage, start your bike, put it in gear, kill the motor and let the clutch out. Pull the clutch in and put the bike back in gear and try to re-start it. Now, do the same drill without letting the clutch out and you'll feel the difference.
Or buy a Yamaha :D:) just kidding and good luck!
Bill :D
Sure you did.
i tried adjusting the clutch play as mentioned above and it helped. also, i start in 3rd gear, bike warm, with hot start lever pulled in and all this allowed me to get that first kick start.
Other than the plug, check your jetting. If it's off, you'll suffer with poor throttle response. I put the "Power Now" on, from World Power Racing, and the bike starts every time. It was always a great starter, but would get fussy on me when I stalled it during the heat of battle. Now it even starts quickly in that condition, which is all I wanted. Worth a look. Also, the air filter on this big pig really needs to be clean. When it starts getting dirty, it will bog and be hard to start. Worth an extra filter for dusty days. Good luck!
Mine has been starting first kick during all my practice starts over the last month. But like you, it fired on the 2nd or 3rd kick yesterday at the HS. I was in the 2nd row anyway so it didn't matter that much.
Finished 9th. Not quite as good as my last HS on the 250F though (3rd).
I also raced a 250f last season and towards the end of the year I learned another "great" secret....after you crank it, put it in gear,(I always use 2nd), kill the motor with the clutch pulled in(DONT let the clutch go!)'s the new secret...push you bike foward about 2 feet and then pull
it bakwards into line, never letting the clutch out. Try this, it worked wonders for mine after I had abused the clutch all year.
I think that little trick there works for every bike. I used that on my KX all last year and it worked out great. The one thing to remember always though is make sure your engine is good and warmed up. If it is not warm the trick is useless.
The problem I see with these tricks is alot of scrambles here don't allow you to have your hands on the controls. I just did a scramble that was LeMans style. I only have two races on the bike, the first race I think that I didn't have it warmed up enough, and on Sunday I got excited and forgot to pull in the hot start lever.
hmmm i ride the same series as sunruh & dont see one brand or another sitting on the line very often... a honda one race & a yam the next.. my honda starts much easier than my 426 did on a dead engine start ( at least for me) & the best thing is IF it doesnt fire on 1 kick you can just kick again without going through the drill... but i still start in neutral just to make sure it fires on 1 kick..
i think sunruhs been kicken back too many brewskis while watching the A/B class races :)
how many races were you at last year loopout?
2 or 3 of the 13.
actually, i am confusing myself. it was the nixon race that had all the crf's not starting on the line. my bad.
at that season end race, both of us were on the same starting line. now, i have a pic of the start. would you like me to show all these fine riders that pic? there certainly wasn't a crf in front of me. nor any other bike for that matter.
i don't drink till i get home.
Thanks guys for all the replies. I forgot to mention I have a Revloc. It still seems like I can try some of the ideas. Off to practice.
The last 2 races the CRF started 1st kick and that Revloc just hooked up-not the holeshot but close. But I think I am going to start in neutral from now on if I can't get better than 50% on the first kick in practice. Its closer to 90% if its in neutral. It didn't matter this race because I flatted anyway. But our track is on water restrictions so if you don't get a good jump you have major dust to worry about. Our starts are straddle the front wheel facing backwards.
Motoman, it seems alot more competitive in Senior this year. I got 3 5ths, a 6th and a 7th last year and this year it has been a 6th, 8th, 9th, DNF. There are some A class MXers in our Senior HS class. People like Aaron Turner have moved up from vet, there are some fast new faces, and then some races Jim Rase comes back from CA (where he works for Honda designing next years bikes, kinda like Honda's Dubach) to spank us all (along with just about everyone else on the track). Unless he has a flat or something, Rase is going to win Senior. I would have been pretty happy with 9th in that dust storm. Did you feel you would have done better on the 250F?
yup i made 3 rounds last year... we had new baby soo i decided to stick close to home & blow off the series (no brainer there) .
Like i said i still start my CRF in neutral to make sure its a 1 kick deal ( usually..always a exception) Also when its cold out i think all brands of strokers have probs.. last year rd 1 at goertz i think half the 4stks had trouble starting.. i know 3-4 my buddies had to change plugs...
Nixon did have a few riders bikes not start... in fact that race mine started then died 5ft out ( not sure what happened).. started dead last & got up to 6th...
go ahead & post the skull creek pic.. i got a 5th place start that race i think & 5th place finish... wont hurt my feelings... had i ran practice or a parade lap i wouldnt have gotten fouled up in the dunes on lap 1 & would have done better...
considering i never go practice woods riding i think i can hold my own very well...
bring the ol BMR out to cross creek sat & i'll show ya the hot lines around the mx track.. me & bobby are having too much fun out there on the weekends....
sunruh...I found your post to loopout...insulting. He was playing around with you about the brewskis. We could care less when you drink. From the way you ride, it would appear you drank BEFORE the race...
Who cares what CRF beat or did not beat you off the start. He never claimed a CRF (or his for that matter) beat you.
I, unlike some others here, don't give a damn that you are a mod. I think you are an insulting, wanna-be-know-it-all punk. Maybe if you would practice more instead of typing 1000's of messages on dirt bike forums across the state, you would be a faster rider. :)
Well...back to the starting thing....Mike, since you use a RevLok, I'll be asking you questions?...I have the z-start coming and I was wondering about "in-gear" starts. I know a lot of 4-strokers start in neutral (if it is Lemans ,then I guess everyone will)...but My buddy always started his 250f in 2nd and holeshotted 10 out of 12 races, must also add I tried the neutral start with about a 5th (out of 24orso), but later I saw a Video of the start and it was obvious how
much faster he left the line, at least 40 feet after turn 1.
This post brings up another question about starting the Crf...I'll post it seperately under "Starting secrets/hints"
  • Similar Content
    • By aminem
      my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
      plz Help
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
