Cam Sprocket Bolt striped...need help..urgent!
Okay, I was able to adjust my valves with the help of a friend. But now, one of the bolts that hold the cam sprocket together has its thread stripped. Can I get this bolt from a hardware store or do I need the real one from Honda? The part number from service.honda is 14322-MN1-670.
Urgent...thanks
Let me guess? Your valves went to "0" clearance? How did you strip the bolt and not the thread in the hole? You could take the bolt to a good hardware store that carries metric bolts and match it up, not anything special about it if I can remember. Just clean the bolts and female threads the best you can with some carb. cleaner and wire brush and dont forget the loctite!
Randy
i locktighted mine aswell.as for the stripped bolt,i wouldn't let that stop me from riding just find something close
If you are worried about balance buy 2 that match the threads of the previous one. Replace them both. If you have the ability to get grade 8 I would recommend it. :)
I didnt strip the bolt. It seems like the dealer that adjusted my valves the last time did it.
They carged me $170 too!
Man, the valve adjustment thing was not that hard after all! Cool! Now I've learned something new... :)
[LowCo]
The shim that was in there previously was 170. I went down to 140 but it was still tight. What size did you use for yours anyways? By the way, I went to a Yamaha dealer and bought the shims there. It fits, and it's way cheaper too. They charged $3 while the honda dealer charged $10 for each shim.
Dog,
I dont buy shims, I hone them down on a knife sharpening stone, and use a micrometer to gauge my progress. Unfortunately we dont have any shops around here worth the powder it would take to blow them sky high! :)
The first time I had a local machine shop surface grind them for $25, but since the L valve was at -0 and I only told them to take off .006 It put it at .002
The next time I did it I discovered the stone trick, and was able to get them right on the money! :D at .006
It only took me a couple of minutes per .001 Well worth the effort to ride instead of wait on parts. :D
Randy
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
