Gray Oli in Transmision case
Hi, Im Cory Kiger I have a 03 CRF 450. Im 15 race in 250B, 4 stroke,And open B/C in District 5. I use honda red transmission oil in my tranmission but after raceing/riding hard it steams and drips out grayish oil from the transmission overflow, and i was wontering what is turning the red transmission oil gray??
Don't you just hate it, when it's your first post, and you type in "oli" instead of "oil" as the SUBJECT??
I wouldn't worry about it too long, however, because you can probably whup my butt, and several others here, on the track.
Hey, welcome to TT. I hope others have a better technical answer than I just did. I've had my CRF450R for 6 months, and haven't had any problems with the tranny oil. I change it about every 5 to 6 rides.
Mine was greyish OIL :) too. No big deal, it's just break in.
If your talking about that hose that has a plug in it, that's normal for some muck in there. I flipped out at 1st when I saw this, but you have to drain this every once in a while. If that's what your talking about. :)
Cory, so a search on the subject. There were a few threads about this topic in the past 6 mo that may be of some help.
Good luck!
It could be the clutch basket dampers. If your clutch gets real hot once (or more times) it breaks down the rubber that honda uses and they start to disentegrate. Best way to check is to pull the basket out and feel for radial play between the ring gear and the basket. This is a pain to do, you have to remove the whole right side engine cover.
This problem was supposed to be fixed in the '03s but I've heard of at least one '03 with the problem.
Look for rubbery chunks in your oil. If your seeing those, this is almost certainly your problem.
I just bought my 03crf 450. My buds ride yz250f's so I have learned from them what not to do. If you look in the owners manual it will tell you about differant oils to use in your bike and the make up of the mixing between the crank side and trans. side. this mix if you are using two differant oils may be your prob. I used the chart and found that I can use the same oil that I use in my Ducati. I use syntex 5w-30 for both. make sure you get the red top. If you read your book it will tell you about the stamps on the back of the oil bottles and gives you an example of the stamps not to use. I change my oil when it gets dark enough that I cant see the holes in the sight glass. It works out to be about 3 rides (This is also the number you will get in the book) some times two. I know what you are talking about when it comes to grey oil all to well. So far I have not ran into that problem yet. Also when I picked up my bike from the Honda shop it had an out the door servic done on it. Well first time out it chattered real bad in the gear box. I put about 8hrs on it and changed the oil (after reading the book). the chatter is gone. I hope this helps but like I keep saying read the book. This bike is picky about things and for once Honda put out a manual that covers most it with out buying a shop manual to go along with it. I hope this helps.
Will water in your trans will make it look gray?
The grayish oil is normal. Mine still does it after about 15 hours of riding time. It's slowly fading back to what oil should look like.
That's cool that you're 15 and on a CRF450. My son is 14 and a little scared of my 450, but I keep telling him he can handle it. Welcome to TT. JED
yes, water and oil mixed will turn grey.
Keep a close eye on your coolant both for level and cross contamination from oil. If it's clean and the level doesn't change, then don't worry about grey oil. If you notice crap floating on the top of your coolant and/or the level is going down, then it is very likely you have a bad water pump seal.
Its aluminum from your clutch drive plates. Change your oil sooner!
The cluthc plates in the CRF450 are steel and not aluminum like in the CR250's. I would look to see if maybe you have a leak in your cooling system. If it is milky, it is most likely water mixing into the oil.
I meant to say the clutch plate separators. Oops?!?
Is it possible for water to get inside the transmission during washing or creek crossings?
Two friends of mine w/ CRF's found gray oil (or water in it).
Seems I remember a post on this before, but a search didn't turn up anything.
  • Similar Content
    • By aminem
      my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
      plz Help
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
