FS: White Bros 36mm PERFORMANCE carb for 85 XR350R
For Sale $150.00 NEW
White Bros. 36mm PERFORMANCE MIKUNI round side carb for 1985 XR350R retails for $197.95
WB PERFORMANCE MIKUNI CARB KITS
- Most of today’s 4-Stroke singles come equipped with restrictive EPA regulated carburetors that make the engine run very lean, along with very poor flow characteristics. By using a Mikuni Performance Carburetor, WB can offer the highest power increase available for your machine. Each WB Carb Kit has been exclusively tested and is sold with the best combination of carb and test proven jetting.
- This Carb Kit is complete with everything necessary for installation. Installation instructions and additional jets are included.
- This carb kit works VERY well with near stock motor and stock air box.
Thanks,
Jason Moffitt
925-352-4388
First $100 gets it!
  • Similar Content
    • By libsead
      Guy's,  I have an 1997 Honda XR400R and I need to do the front forks.  I'm a big guy 6'4" 375lbs.  So far I haven't been able to find a setup for a big guy. Any suggestions besides losing a lot of weight. :-)
    • By Scat Adams
      OEM Rear fender from an XR400. Fender includes Baja Design tail light as well.
      $20 plus shipping, located in San Diego.
    • By Alex John Blanch
      Went riding on Christmas Eve  everything was working fine went through some mud and slipped dropped my bike tried to kick start it and the kick start went limp pushed it back up got compression again  kicked it over a bunch of times started to run again  rode it for the rest of the ride with no problems then on the way back on the road I gave it fill throttle  and it died hasn't started  since and now has little compression. Replaced the spark plug and changed the oil and filter and adjusted the valves but still very little Compression and won't start.
      Any ideas??  Would greatly appreciate
    • By Ricky Bobby 21074
      I have a 1986 xr250r, I'm interested in converting the rear drum brake wheel assembly to a rear disc brake system. Has anyone done this, and can you tell me what application parts will get the job done. thanks
