Is there any difference in the suspension between the "S" and "E" models? I'm trying to decide which to buy, I'm leaning toward a yellow "S" model.
From 2002 (I think) onwards, no difference. Before that, 'E' was better.
'02 and newer are the same.
2001,2000,the suspension sucks for any serious trail riding $250 to $500 will get you a decent suspension system.
Yeah, the 2000 and 2001 S models do not use the cartride type fork. You can still get them to work pretty good with new springs and emulators. From 2002 to present, all DRZ's have the exact same suspension regardless of model.
yeah those bastards!!!
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
