PTFE product for DRZ motors
hi, i have a drz250. . . is it ok to treat the engine with high concentration PTFE type engine coating product?
or is this going to mess up the clutch/transm. mechanism?
EC type oil effect or EC oil ok on these bikes. . . help.
'03 DRZ250
i dont know what that is that you are mentioning but i would not put it into the engine unless it is a motorcycle specific motor oil. any friction modifier of any type will cause the clutch plates to slip which not only increases wear but also increases heat due to the added slippage friction. sitck to full synthetic motorcycle specific oil once the break in is done. if the engine is new, i would only recommend a petrolium based high quality oil like that offered by motul, or valvoline 4 stoke oils. the valvoline oil is only 2.50 a quart and works very well. i keep a couple extra quarts as back up cause it works well and is cheap enough to be used once and dumped. do a search for motor oil for WAY more information then any sane person could handle in thier life time.
Snake oil can not replace regular oil changes and quality oil. Call me old fashioned.
Don't use that stuff. You are correct - it will screw your clutch!
Check out this site, it may help in your decision making. I found it interesting that the teflon (PTFE)is a solid and it doesnt change its state no matter how fine or microscopic the particles are and most of us have been taught that eliminating solid particles from the oil and engine is the best way to prolong your engine life. At any rate it is a good read and no matter what I put IN my bike it wont change what I put ON my bike!(namely me) :)
The key to long engine life; no matter what oil you use- change it regularly. As Hotler said, stay away from the snake oil stuff.
It's Teflon. Microscopicly it looks like little balls. I wouldnt put microscopic balls in my motor. In theory it works but I'd just change the oil every 3rd ride if not sooner.
Does anyone now what's in the lead substitute fuel additive products that is supposed to reduce valve wear? Is that also PTFE?
No you wouldn't? you just put them on your seat!! ha ha ha just kidding I couldn't resist :):D
Lead substitute fuel additive is for the most part lead.
Some (pre 85? )engines needed lead as a valve stem/guide lubricant.
Teflon has to high of a flash point to be used for any type of combustion. Heck the melting point is something like 600f.
Lead (Pb) substitutes are primarily made from heavier aliphatic (longer chain) hydrocarbons. They act like two-stroke mix oil to lubricate the valve & guides, cylinder but will also burn off. Tetraethyl lead as an ingredient in any additive-that can be used on DOT jurisdiction-was phased out due to the environmental Pb residues it leaves behind and the outright hazards it presented to those using products containing it. If your looking to use a Pb substitute; save yourself some money and mix your gas at 200:1 using two-stroke mix oil. However, in using either the Pb-substitute or mix oil, I'd suggest checking your plug more frequently for carbon fouling. Enough on chemistry - where's my bike!!!! :)
OK. thanks for the tip Briter. I was going to start using Pb sub this year cuz many people have said that using leaded fuel halts the valve recession. Not sure if Pb sub will do the same or if it will foul my plug, but I will try it and post the results.
I was told a few years ago that adding lead substitute to unleaded gas will increase the Octane rating substantially. Do you know if that's true?
If so it seems like a good way to make regular unleaded into "race" gas.
If not then, never mind.
HEHEHE I wish they were every time I smack em on the tank!!
If you're looking for higher octane - don't waste your money on Pb substitute. Octane is gained by the percentage of aromatic hydrocarbons in your fuel. Pb substitute, remember is primarily aliphatic hydrocarbons. If you want octane boost add xylene or toluene to your fuel. About a 100 milliliters (3 1/2 ounces) to your full tank should heat things up nicely. Don't go crazy, remember higher octane will also run hotter.
i always thought the higher the octane the cooler it burns......-jamie
Leave the teflon junk on the shelves as well as the rest of the motor oil additives. :)
yes it does!unless its one of the new generation highly oxygenated race fuels.
You guys are mixing up the idea of a more efficient burn with the term hotter. Higher octane will burn more efficiently with more energy available to drive the piston down. As the piston works harder, more of the energy produced will be lost to heat - hotter run.
  • Similar Content
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
      Since I've been getting a few requests a week to e-mail the re-jet instructions word document (offered to send it to someone in old post that lives on) I thought I'd throw this post together. It is perhaps the one stop shop for 3x3 mod info: the master 3x3 post
      The 3x3 Mod
      So what is the 3x3 mod anyway? Well, this mod is basically re-jetting your carb and allowing it to run to its full potential. This mod can be done by even the most newbie of wrenchers out there. 3x3 refers to the size of hole that you will need to cut into the top of your airbox where your snorkel currently is. Don’t worry, you are not carelessly risking getting water into your engine by removing the snorkel. The bread and butter of the mod is the taper of new needle which you will get with your kit.
      Jet kits can be found through the TT here
      Scroll down to the bottom to find the right kit for your DRZ
      If you purchased a S kit for SM by accident don’t worry it will work (different jetting specs are used, just ask!)
      There are some great instructions outlining the procedure and here are two:
      bayoubikebruiser’s post is a nice one (Good Job BBB)
      Note that BBB followed the TPS sensor wire back and detached from the clip it there rather than removing the TPS off the carb.
      Another read is the attached word file (which i convereted to pdf and can be found here for your convenience) which has ‘been around the block’ to say the least.
      Sample Jetting recommendations (note: these are different for different elevations and different bikes)
      - 150 main jet (155mj for full exhaust system)
      - 25 pilot jet
      - 2nd clip on needle from top
      - 2.5 turns out on fuel screw
      - 140 – 142.mj (bigger for exhaust)
      - 25 pilot jet
      - 4th position from top
      - 2.5 to 3 turns out on fuel screw
      Burned’s fuel screw setting method:
      with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
      this should happen between 1 and 3 turns out.
      if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
      choose the appropriate size and retest.
      The 25 Pilot jet part number for TT is:
      So… now you have the info that you need, get to it! Your bike will sound better and rip a little faster; get ready to grin!
