My 03 Wr450 dirt to street project
crazyz250 your doing some great work here man.this october i got a mighty hefty check coming in and am going to pik one of these bad boys up and build it like you are over the next winter into a street legal supermoto.altogether how much is it for rims/rotors/brake relocation
I will have about $6000 into this bike when its all said and done. a bit more then i planned on spending. Doing all the work myself and finding the parts here and there to me is what makes it fun and worth it - knowing i built it myself. I got lucky and got the rims/tires for $1000 shipped. Front rotor was $120 and i have yett to find a bracket ~ $40. go to baja designs for a street legal kit ~ $500 Id say $2000 would cover a basic supermoto setup. Withen two weeks the bike will be nearly finished. all i need now is a tank, seat cover, rear rotor and paint the headlight housing black. cant wait!!!!!!!
except we are getting 10-14 inches of snow tonight into tomorrow :banana: Which means it all needs to melt before i can ride ahhhh
ya i figured it would be right around 2k maybe a little over.what did you do to the motor when you had it tore down.i know for my raptor 700 a 11:1 piston and cam was the best reliable bang for the buck but not sure on these which is what i will want for the WR
I was thinking of doing that, where did you put the batt? i was going to cut a big hole in both sides of the airbox for more airflow, but id rather not. If i have to trim the seat thats no big deal im going to get a black seat cover anyway
I removed completely the battery!
i cleaned everything up but just left it alone. it ran great so there wasnt a point to rebuild it. i am going to do the valves before i put the tank on. the motor is enough enough to pull if i ever needed to do work on it
hmmmm i like my electric start haha. i am going to fab something up for an intake, not sure what tho....
if u want a sweet custom seatcover for this i'd go to jettrim.com
i just checked them out i look like they only make them for quads maybe im wrong? nice covers tho
For now i am sticking with a KnN instead of making my own airbox, i can always do that later.
Braking 320mm front rotor, still looking for a relocation bracket is anyone has one that would be awesomeee
bet you cant wait to see what this is going to turn into :)
To make 03 YZF plastics fit on 03 WR heres the list of shit to do
Cut left hand side of rear fender like so
After that it bolts rite up with room for your over flow tank
Next cut the left hand side airbox cover like so
Before
After
Except you now need to find a place to bolt the bottom of the side pannel to because it will stick out if you dont...im still working on that
Back end is on
used to look like this pile
i am a tad bit stupmed (if you cant tell haha) on how to mount this taillight. once the seat is on i only have a 1/2 inch of room to have a mount on the back of the fender, the mounts on the taillight seem to be in the worst possible spots. this calls for some more beer then ideas might start flowing
some more shit i got in the mail woohoo!
As she sits until Friday when i have a full day to fab up some stuff. Hopefully i will have my order from motostrano in. I ordered 5 items from them on Jan 17th and STILL have yett to see them. they said they had one item on backorder and it would ship in 2-3 days that was the beg of last week. BS if you ask me. id have this whole bike done in a weekend if i had all of my parts. Friday should be another update if i get my parts...
still need to buy
Rear brake rotor - anyone have one??
clarke gas tank, black - What size is an oem yzf tank?
full exhaust
Very nice! It looks great already!
The YZF tank has 7lt capacity.
If you can buy UFO black rear panels you will find the solution for your problem with the airbox. As you can see from my bike the left panel divides to two pieces. The small one bolts right on the airbox just like the stock and the the big panel fits great!
hmmm i ordered acerbis ones for a yzf i dont think they had UFO ones or maybe they did im not sure. so the UFO ones can fit either a yzf of wr with the cut out like that? i will make mine work but if i had known it would have been easier i would have bought UFO ones!!
Ah ,bad luck. It would save you from all this trouble. Still if you are not happy with the result you will have with the cut acerbis panels, the UFO ones will do the job!
what kind of paint did you use on your headlight? im going to paint it today or tomorrow i have some reg semi gloss dont feel like spending like $9 on some plastic paint that prob wont make a difference.
and i thought mounting the light was going to be a problem. I had to soder in a ground for each turn signal for it to work correct, and switch around some wires for the brake light. i WILL make it work
Cleaned up the wires a bit
beastttt
Thats just the beginning of my sick nasty custom fabrication haha. more to come later this week
told you guys i wouldn't give up on the taillight!!!!
finally got it wired up blinkers/running lights/brake lights work perfect! to mount it i just cut off a few of the OEM mounts and did some cutting and just bolted it to the rear fender. worked out really good i was surprised myself.
yeaaaaa
custom mounting bracket for the speed sensor of the vapor system
holy brakes batman!
pure sex
Black clark gas tank 2.9gal will be here next week!
Good progress...
thank you... i thought people forgot about me :lol:
i am happy with how it's looking so far, some more custom mounts to come this weekend
