Chemical cleaners
Basic question,
What is the difference between Contact Brake Cleaner for $2 bucks at Auto Zone and the Contact Cleaner for $7 bucks at Cycle City or Cycle Gear or any Motorcycle dealer? I want to use it to clean out my cables before I lube them.
The difference is $5.
See ya tonight at Perris :)
Dang I was beat off the line
That's what I thought. Nothing!
Bikes all ready to go. I get off work at 5 and should get there by 6:30. I hope it is not going to be a zoo tonight.
The real difference is how many good brain cells it will kill. Between contact cleaners, brake shoe cleaners, carb and fuel injection cleaners- Look for a degreaser/cleaner that does not contain TCE Trichloroethane or Methy/ methylene chloride. They are suspected or known carcinogens, If you have to use them, use it in open air or a well ventilated room.
The cleaners least harmful but still need ventilation contain hexane or pentane product as the active ingredient.
Then I consider the price.
So what are you saying? Don't drink the stuff? j/k
I also use latex gloves when working with any chemical.
But what I am really worried about is if a Brake Cleaner will ruin rubber oil seals and cable casings. That's is why I made the post.
funny story: I was carrying a pan of antifreeze out of the garage one day as this old homeless dude is pushing his shopping cart by. He looks down at the pan and says, "Hey, how bout a drink of some that?! I stop in my in tracks as I am thinking "are your serious?" Then he laughs and laughs as he keeps pushing his cart down the sidewalk.
I think that's a valid concern. I thought lubing cables was a 70's thing. Modern cable sleeves are Teflon lined and don't need any lube. Brake cleaner probably isn't good for the Teflon lining. Adding lube will attract dirt and make them gummy thereby setting up a vicious circle. Better to keep them clean and dry, IMO. Of course, the bike shops will gladly sell you cable cleaner, oilers, and lube.
One of the biggest lessons that I have learned in my years is the detrimental effect of residues left behind by cleaners, especially those that claim to be residue free.
These residues can glaze up clutch plates, destroy brake pads, ruin rotors, cause seals to stick and swell, and harm the overall performance of the component that you assume you're doing a favor. In many cases, residues from solvents can greatly diminish the performance of operating fluids such as suspension and brake. Hence the reason you would never want to use a carb or brake cleaner type solvent in rebuilding a shock or fork, (and believe me, many shops even make this mistake).
Regardless of what you use and where you purchase it, determine for yourself if it leaves a residue.
Sample spray about half an ounce onto some clean foil and allow the solvents to evaporate. In many cases, you'll be surprised as to what's left behind, not to mention how oily they are. You might as well spray WD-40 on your rotor for how messy many of the "residue-free" brake cleaners are.
Sometimes more harm can be done by a person that keeps a bike too clean when done improperly, verses the person that just leaves it alone.
So far this has been a good post, I am learning alot from you guys.
Thank you for sharing. :)
The cleaners with hexane and iso-butane are less harmful and cost more. You still need good ventilation. Avoid the TCE and methylene Chloride products. They are a cheaper product to use, not cheap enough to sacrifice your health.
If you have to use products of this nature go to an automotive paint store and get a disposable organic respirator. They are $15.00 to $20.00. I use one when spray painting acrylic enamels and cyanide based primers- even when outside.
I do not lube my cables because it gumms up. If you cables are dragging then replace them.
cable casings????you mean the coiled metal material that the cables run through? unless its acid the "casings" will be fine...i like triflow lube...unless you use belray chainlube it should not gum up.if you want to clean out a cable ,gumout carb cleaner will get it spotless...and totally grease and gum free.after you get it clean then shoot triflow into the cable with the little swizzle straw that comes with it....
honest anwers here....doesn't triflow smell like those candy necklaces we used to get when we were kids?
and doesn't klotz 2 smoke oil smell like play dough?
2000 yz426f
gold answer protapers and tripleclamps,FMF Powercore 4 muffler,FMF Powerbomb
Proaction suspension, front and rear springs,+revalved (Reese Firestone
mechanic) ,mxhouse custom billet aluminum,machined brake pedal w/ pivot end
mxhouse carbon fiber rear caliper guard,Michelin starcross tires ,
complete engine rebuild by Wernsdorfer Racing Service,renthal 49/14t
chainwheels, d.o.d. chain,sealsavers ,progrips ,
2003 yz450 swingarm and bushings,devol frameguards,gripper seatcover
I love Triflow, but you can't find it anywhere around here anymore. I used to work for a tradeshow exhibit house and one of our clients was Thompson/Formby Co., the maker of Triflow. Before I quit, I had picked up cases of the stuff, 8 oz. spray, 12 oz. spray, little squirt bottles, gallon can. Needless to say, I am set for awhile, I quit 3 years ago, still have loads of it.
By the way, I am a fellow Pipefitter/HVAC Service, Local 614.
Nothing smells as good as Maxima Castor 927 and race fuel. It has sort of a sweet smell.
cool ddz...i hope you have some inside work... is it as cold in TN as it is in MD? this morning 10 degree's....have to heat up the deisel fuel...
  • Similar Content
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
    • By Goof331
      Does anyone know if there is any differences between the 2 radiators? Will the yz450fx radiator bolt on a yz450f? What I am wanting to do is wire up a fan to my 2016 yz450f. I know how I am going to do it I just don’t want to use a “universal” fan kit. What I would like to do is get a 450fx radiator and the direct bolt on Trail Tech fan for that radiator to have a good clean look.
