Stupid question time!!!!
I have read under different boards (Yamaha) that they do something to the airbox to increase airflow. Do any of you guys do anything to modify your airboxs?
Some guys drill 1" holes in the side cover of the air box. They then cover those holes with a filter or screen.
Mine is stock. No snorkels or lids to remove. IMO holes are not necessary, mine breathes just fine. Holes will only allow more dust in (even with filters) and make it difficult to wash (you'll have to cover the holes or close louvers wich may leak anyway). Try running your bike down the street without the filter on and see if you get any more power from the increased airflow and make your own decision. I found no appreciable difference (other than different intake noise), so it has remained as delivered.
Also think about this; how are those holes and their air filtering method (metal riveted screens or inserted foam filters) going to hold-up to the constant abuse of your boots rubbing against them? The job had better be done correctly because your engine's life now depends on it. The factory has done plenty of research to garner the most power with the most reliabilty and passes that on to you in it's product. You as the final owner get to decide if you want to compromise their design for the sake of a SMALL horsepower gain (which can be obtained through more reliable sources). I would personally never purchase a bike from an individual who had cut holes in his/her airbox. Just my two cents.
works for me. Thanks.
that sure makes sense to me...do i really think that i'm smarter than the engineers?? i don't think so!!! keyryist..man how much power do you want??? just a thought..
Yep. I cut a 3" x 3" hole in the top of my DRZ airbox. It was otherwise breathing through a small hole. Made a huge difference after I rejetted.
Now my YZ, that needs no changes. Stock the hole is big enough. In fact I taped up a portion of it to eliminate dirt protrusion in one location. And I still get holeshots.
Oh yes, Paul, we are not smarter than the 'engineers', but sometimes we are smarter than the DOT who imposes emissions regulations. In my case, my DRZ could barely breathe the way it was stock. After surgery, I went from a 142.5 main jet to a 150. The change was nice, I have to tell ya.
  • Similar Content
    • By TheCurtster
      Hi all,
      Well, I’m finally putting my faithful 97 XR400 out to pasture, and have joined the KTM family with a brand new 500 exc.  if Honda would only make a lightweight 400 size dualsport bike, I would....   never mind, that’s a different thread.
      So here I am.  I don’t race, I’m getting old, and this will probably be my last dirt bike I own.  I’d like to keep it for 20 years like I did with my Honda.  I’ll try my best to keep up with the flood of maintenance (what’s the crank rebuild interval for a XR?  40,000 miles?). Anyways, looking for suggestions so I can enjoy this bike into my 70’s.  A skid plate looks to be needed, and some way to tuck the license plate up and still be legal are in my future.  Thoughts?
      Thanks,
      Curt,
    • By Jay_112
      Hey all,
      My name is Jay and i'm new to the forum community but not new to the sport. However I have reached my limit with my expertise and am hoping some of you may be of some help. Without further ado...
        I've stuck to a track most my life, I.E. Motocross, arena cross and outdoor national style tracks. I've made the difficult decision to leave to tracks to the young guns and ride more single track and trail riding up in the mountains. So i started by selling me Factory SLM racing 2012 Yz450F, yes i cried when he drove off with her. But i looked to greener pastures with hopes to have a KTM 500exc, Beta 500rr-s or a Husqvarna FE501. However, almost a year later and I still don't have a shiny new dirt magnet in my shop. I'm in the final deliberations and have narrowed it between KTM and BETA, with me leaning towards the BETA. This is where you come in.
      I would like to know the following.
      Is the Beta service intervals as daunting as the KTM's?
      Is the cost of parts between the two noticeable? And are the just as readily available?
      Those that have a 2017 of either bike, How are they holding up? Can I expect this bike to hold up like a 1985 XR250 (An almost impossible feat)?
      What are any major concerns about either bike?
      and finally what made you choose one or the other?
      Thank you for your efforts and advice. I appreciate it.
    • By jaworskime
      I have had this issue happen twice,  my efi and low fuel light are coming on, the bike will idle but soon as you give it gas it will sputter and die. The lights aren't on until you roll the throttle back.  Any ideas? Also the electric start won't work. Have to kick the bike to start,  and the computer doesn't come on when you turn the key and flip the switch to start,. Assuming it's a wiring  issue or fuel pump issue,  any help would be appreciated.
    • By motf
      quick, question - is it doable without removing the tank?
      thanks
    • By KeyKeeper
      I noticed my shock spring almost touching my exhaust on 06 525exc.  I pushed on the spring with my hand and the swing arm moved over 1/8"!
      I know that cant be right but looking at the schematic view of the bearing layout, wth holds the swing arm from moving side to side?  I see the bearings, sleeve, seals and some small cap type things that go on the end of the sleeves  (outer end) but what actually keep the swing arm from sliding side to side inside the bearings?  Looking at mine there appears to be some sort of spacer on the left side between the swing arm and frame beam but on the right, it just looks like the sleeve mates up to the frame?  Am I missing something on one side?  Got this bike in a trade.  So far the motor has been rebuilt at cannon racecraft in OKC, forks rebuilt, and its super clean and runs great other than it needed valve lash set.  So it seems odd that an important part like a swing arm spacer would be mia.  Any ideas?
