OT: Slightly, DRZ Low Gel on an RM?
Is the seat base on a DRZ similar to one on an RM? Short guy here would like to add an '03 RM250 to the stable but would like to lower the seat height. I hate the idea of cutting down the original seat, I've tried that and I just don't get enough support with the thinner foam for my lard butt. Went to a dealer and they couldn't tell me and wouldn't remove the seat base from a show room model to help me out. Guess where I won't buy my new toy. :)
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
