Will 53T sprocket fit stock chain on new 450mxc?
I am now using the stock 50tooth rear sprocket and have changed to a 13tooth on the front. I'd rather go back to the stock 14tooth on the front and go to 53tooth on the rear but, do I need to add lenght to the chain or will the stock chain accept the bigger rear spocket?
Thanks for the info
You will most likely have to add length to the chain to do that with a 14t CS sprocket.
I seriously doubt it. Even if it did, I wouldn't run it. By pulling the rear wheel up that far in the swingarm, you're impacting your bikes handling.
