throtle cable 120
what throtle and cable do i use on the 200x carb"the 200x cable is too short and the stock xr 100 is too long am i using the wrong throtle"i'am using xr 100????????
1978 Huffy 10-speed, make sure you lube it up though :) Sorry kids I've had one too many YUENGLINGS and it's bedtime :cool::D :D :D :D :D :D :D :D :D :D ;):p:D:cool: :cool: :cool:
I use a CR80 throttle and cable and it works great.
I recieved a 200x carb which must have been the later version, because it had the cable housing elbow perminently attatched to the mixing bowl cap. Honda puts a spring ring in the cap then pushs the elbow in and it clicks on, like your stock xr100 set up. I also baught a cr80 throttle and cable which turned out too short. There may be different generations, I asked for a 1997,it was too shorter than the stock 100 cable. I then cut and ground out the elbow on the 200 carb. I then, cut the stock 100 mixing bowl apart and pealed it away from the cable elbow. Then I pulled off the chrome cap on the end of the cable housing trimed the plastic sheathing about12mm back. Now you grind about six rings of the cable housing, very carefully with a grinder wheel. Making real sure you dont touch the inner cable.Make sure you remove the snap wire on the cable elbow on the 100 cable your going to use and put it all together. Works great. If you have a problem give me let me know. I put mine in a stock framed 120 with all the usual cam etc totally ventilated air box, so far 125 main stock 200 needle in #2 position 35 pilot 3.5 out on air screw and it runs pretty good I'm not done jetting, but its in the ball park now. See Ya, Matt
Thats a lot of work. The CR80 cable ('96 to today are the same) should have been right length as thats what I used on the 2001 XR80. Must be why I like Mikuni carbs..... :)
  • Similar Content
    • By Tanker01
      I have posted about this bike a few times already but I wanted to make one single post on all the modifications I am doing to it. I am attempting to do everything as cheap as possible without sacrificing preformance. Prices and links will be provided if possible.
      Mods:
      DIY Rear suspension lift [1/4" steel plate]
      Filter screens removal
      ATC 200x Carb [https://www.amazon.com/gp/product/B00AVYXOZS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1]
      Airbox mods [not doing a pod, needs to be water resistant]
      Aftermarket CDI and Coil [https://www.amazon.com/gp/product/B00HG0EDGY/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1]
      DIY Frame cradle [available for purchase but I want to make my own]
      Misc Exhaust mods [none yet]
      Headlight [have one from an XR600R installed, not wired yet, need voltage regulator, have one that may work from XR600R]
      I have another post about my progress on the rear end lift but I am going to be updating on that on this post now. I am working on designing a new shorter main link to lift the rear end in the cheapest way possible. Carb, CDI and coil are all ordered and on their way. Pictures will be posted regularly as I check items off the list.
      Some info on the bike. I traded a non-running incomplete parts XR600R for this bike and got it in a non-running condition. After some cleaning and adjusting I finally got it running. I grew up with one of these so I am excited to have one again. After some looking around online I have discovered there is a huge following of modifying and even racing this seemingly tame bike. Most of the parts I will be installing arent performance parts but simply replacements for the OEM parts that are now 28 years old and cheap and easy to replace. As I am currently in college most updates and work on the bike will be done on weekends. Any DIY parts I make will be run through FEA testing to validate strength and viability and have 3D models and engineering drawings available for anyone else to use to reproduce them [in college for mechanical engineering]. Most of the parts are simple but I like to practice good engineering. I also have a '85 XR600R that I will be working on at the same time as well as my '06 YZ250F race bike so if something goes wrong with either of the bigger bikes this project may be put on hold for a while. Nevertheless, I will continue to update anyone interested in this project and am open to any suggestions or advice from any of you thumper experts.
    • By Alex Wren
      I got 2002 XR200R and I got ‘88 forks for it and they will not fit into the triple trees for they are too big. Do I need the triple trees off a ‘88 xr or is there something else going on with this.
      P.S. I’ve checked part numbers and everything is correct.
    • By Tanker01
      Wanting to buy a TK link for my '89 XR100R. I have looked on the internet high and low for a used one so I don't have to shell out a ton of cash for a new one. If someone could help me out or point me in the right direction it would be greatly appreciated.
    • By Tanker01
      So I just picked up a 1989 XR100R in awesome shape. I plan to use this as my pitbike/parts getter. I have done some looking around at cool mods people do to these bikes and the aussie lift has come up multiple times. I fully understand how the lift is done but I haven't seen anyone say how long it lasts or if it breaks eventually. Obviously the longevity of the lift mostly depends on the quality of the welds, but are there any inherent risks that come with doing this to the bike? I honestly just think it makes it look better and I also plan to put the front headlight and plate from an XR600R on it as well as a tool bag and a few other things, so my main goal is to make it look like a baby 600. I have had these bikes before and I love how they ride and how reliable they are, I'm just worried the aussie lift may cause me issues in the future. I do not plan to put different shocks on the bike and will not max out the rear lift as to not make the bike super squirrley or twitchy. Any insight would be appreciated and if anyone has documented the process of how they did their lift I would love to take a look!
      (For those who do not know what an Aussie lift is: It is essentially relocating the bottom shock link mount slightly higher [most say no more than 11mm] so that the bike sits higher in the rear)
      I will post pics of my bike as soon as I get a chance for those who would like to see.
    • By _RaStA_RoCkEt_
      Howdy.
      Got myself a CA-Plated '90 XR100R, which is awesome. Used as my little slam-pig. Fantastic bike.
      ANYHOW; Just raised the front end with some 03' CR85R forks, which was a swap from the 80's disc-brake 19' KX80 forks I used to have on there.
      (The KX front end wil lbe up for sale soon, btw)
      Just wanted to ask the best possible way to go about raising my rear suspension, and it seems like users have gone 3 ways;
      1) Cut some 7/8 or 3/4 steel plate into spacers and use a longer bolt in the linkage to extend the travel. (Easiest)
      See Link (1)
      2) 'Aussie Mod/Lift' the rear end by cutting and re-welding the linkage mounts higher on the bottom of the frame (Mid-Difficulty) (thank SoCalXR, et-al.)
      See Link (2)
      3) Modify an existing swinger from some other bike, or even a whole new frame (CR85R? / KLX110? / SX65?) to fit, and then running linkless. (thanks SettinTrendz, et-al.)
      See Link (3)
      What do you reckon the best REAR END SUSPENSION LIFT OPTION for a play-bike/Minimoto?
      I'm 145lbs, 6ft tall. (ya, string bean) and before these mods, was riding the bike pretty much as hard as I could. I want something that'll hold up to the abuses of a full size human railing on it off road at the OHV or in the city.
      Thanks ya'll.
