02 400SX vs MXC motor differences?
Hey guys,
I've got a buddy interested in a new leftover 02 400SX. He was wondering what all differences there are in the motor between the SX and EXC for 02. I know the differences aren't as radical as the gap between this years 450EXC and SX but I'm not sure of the exact differences.
Things I'm sure of:
-No happy button
-6 speed close ratio/MXC tranny
Things I'm not sure about:
-Smaller lighting coil
-Lighter flywheel
-Different CDI mapping
If anyone can confirm the above and tell me other differences, I'd appreciate it. I know all the chassis/suspension/exhaust/etc differences so I'm just curious about the motor specifics.
Thanks
Hey Jeb,your right on the things your sure of and as far as the lighting coil its only 40 watts,but I have a light (sometimes)on mine and its plenty.Way lighter flywheel weight,and yes a different mapped black box..Now that mine is a 450 it stalls easier than what I would like but I'm working on it..You also have the big 48mm forks with pre-load adjusters on top.And the shock has high and low speed compression adjusters that they have since discontinued.Probably the best bars KTM has ever built as far as bend goes which they have also changed..I just noticed you knew all the suspension stuff already sorry!!!I think thats just about it.. :)
Thanks Fen.
  • Similar Content
    • By Jay_112
      Hey all,
      My name is Jay and i'm new to the forum community but not new to the sport. However I have reached my limit with my expertise and am hoping some of you may be of some help. Without further ado...
        I've stuck to a track most my life, I.E. Motocross, arena cross and outdoor national style tracks. I've made the difficult decision to leave to tracks to the young guns and ride more single track and trail riding up in the mountains. So i started by selling me Factory SLM racing 2012 Yz450F, yes i cried when he drove off with her. But i looked to greener pastures with hopes to have a KTM 500exc, Beta 500rr-s or a Husqvarna FE501. However, almost a year later and I still don't have a shiny new dirt magnet in my shop. I'm in the final deliberations and have narrowed it between KTM and BETA, with me leaning towards the BETA. This is where you come in.
      I would like to know the following.
      Is the Beta service intervals as daunting as the KTM's?
      Is the cost of parts between the two noticeable? And are the just as readily available?
      Those that have a 2017 of either bike, How are they holding up? Can I expect this bike to hold up like a 1985 XR250 (An almost impossible feat)?
      What are any major concerns about either bike?
      and finally what made you choose one or the other?
      Thank you for your efforts and advice. I appreciate it.
    • By jaworskime
      I have had this issue happen twice,  my efi and low fuel light are coming on, the bike will idle but soon as you give it gas it will sputter and die. The lights aren't on until you roll the throttle back.  Any ideas? Also the electric start won't work. Have to kick the bike to start,  and the computer doesn't come on when you turn the key and flip the switch to start,. Assuming it's a wiring  issue or fuel pump issue,  any help would be appreciated.
    • By motf
      quick, question - is it doable without removing the tank?
      thanks
    • By KeyKeeper
      I noticed my shock spring almost touching my exhaust on 06 525exc.  I pushed on the spring with my hand and the swing arm moved over 1/8"!
      I know that cant be right but looking at the schematic view of the bearing layout, wth holds the swing arm from moving side to side?  I see the bearings, sleeve, seals and some small cap type things that go on the end of the sleeves  (outer end) but what actually keep the swing arm from sliding side to side inside the bearings?  Looking at mine there appears to be some sort of spacer on the left side between the swing arm and frame beam but on the right, it just looks like the sleeve mates up to the frame?  Am I missing something on one side?  Got this bike in a trade.  So far the motor has been rebuilt at cannon racecraft in OKC, forks rebuilt, and its super clean and runs great other than it needed valve lash set.  So it seems odd that an important part like a swing arm spacer would be mia.  Any ideas?
