On the fly clutch perches. Which one?
I am about to buy a on the fly perch, and was wondering if I could get some info on which one is the best? Ease of pull, strength, reliability? I've never owned one, but used my buddies, and it is sweet, he has the works one. I really like the oberg one though. It looks like that one is far better than the rest. Anyone have one?
I have a works connection with the shorty hot start thumb lever. I like it a lot. It is easy to push the hot start and pull the clutch in to start in gear and the thumb lever doesn't get in the way whatsoever. Very good craftsmanship and quality also. I would highly reccomend this one. Very easy to adjust when in the air also.
I use the FMF 909 AOF perch. I also use the Dr. D hotstart on the throttle side. I like the setup although I would probably do the Works Connection setup. It is just a little cleaner.
I agree with you redracer21 , i have the same , had ridden with it only once and it is awesome , it's wonderful .
Very easy to adjust but never had the "chance" to try to start the bike in gear with the WC perch , does it really start in gear with it cause with the stock one not possible .Do you adjust it very tight , no freeplay?
For the price it's good but you can't compare the WC with the Applied , it's not the same quality .I agree with you it's not the same price.If you want a good perch without spending too much money go for Applied but if you want the best go for the WC!!!!Sorry if i hurt someone but it's the truth. :)
No hurt feelings here! :) I think Works Connection is overpriced for what it is...just my .02 worth.
I am not a "trendy" guy, hell, I am not even gonna buy the replacement hot start lever for $50, I just moved the stocker over to the right side, turned it upside down, it is now easy to reach because it sits to the left of and slightly in front of the brake master cylinder, keeps my hand off of the throttle for hot starting, and keeps my wallet happy.
I cut and welded my clutch arm to add 5mm, and I also had my cable bracket at the engine cases welded to make it stiffer, no need to buy a $50 part that barely makes any difference anyway.
Call me "team neccesary" :D
Get a magura hydrolic clutch.Never needs adjustment because it doesnt fade, you can also adjust the distance from the grip to the lever to your liking.Pull is less than stock and smooth.
I don't like clutch free play. I run the smallest amount possible.
As far as hydraulic, I've never ridden with one but I've heard that it's either off or on, no slipping. Just what I've heard- i know you can't believe everything you hear.
Ive got a WC peice too. Damn sweet.
I dont mind the cheap ones either. There are several companits selling the idnetical unit. Mine said MSR on it. It is forged, so it can be straightened. You miss all the beautiful machine marks, but otherwise the thing works.
I still like the stock honda cr perch the best. damn shame it wears out so quickly.
Redracer,you were right , thank you , i rode the bike today and i trained to stall . The bike started first kick even in gear ( 1st,2nd...) each time before with the stock it was impossible for me ( it is possible that i was doing wrong with my fingers ).It's very easy with the WC to pull the clutch and the hot start together. I love this perch ( i hope that it will last for a long time lol) :)
I really do like the Works Connection unit. I found mine for about $125.00 You could buy a cheaper one if you have the Power Now device, because you won't need the hot start function any more. I got the Power Now so my bike would re-start more easily during racing stalls. It absolutely works. Yahoo!!! :) The 4-strokers really need clean air filters, too. A slightly dirty filter will make the bike much harder to start. A mechanic recently told me the filters on a 4-stroke really flatten out when the throttle is on. That's why these guys who take the filter screen off have their filter sucked into the intake! Just one more "tidbit" that's bound to help somebody.
Rage on!
Do you have an address site for the Power now?
You asked: "Do you have an address site for the Power now?
Mine came in a package from "DSP", with DSP logos and stickers. The same DSP that makes pipes and carbon fiber parts. They must be together. White Power was the old name. Maybe that has changed. Look on DSP's website. That's probably your best bet. Good luck.
I have to admit, I was hesitant to spend $150 for a clutch perch but now that I've got it, I wouldn't part with it. I love the on-the-fly-adjustment and even like the hot-start being moved to thumb operation.
I've got a Power Now on my 450 and like it as well. Really adds some snap to the power and makes it crisper. Eases the starting as well but I have had to use the hot start a time or two... The website is www.worldpowerracing.com and yes, it will come from DSP. Takes about 3 weeks - or at least it did for mine.
Do you use stock crf levers with the works connection perch or do you have to buy more expensive replacement levers when they break??
Stock Yamaha! Sorry, I couldn't resist... :)
  • Similar Content
    • By aminem
      my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
      plz Help
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
