My forks are leaking oil.
Today when I was starting to put on Maier fork guards on my bike I noticed there was a puddle of oil under the front wheel. After closer inspection I noticed there was oil leaking from the black rubber fork protector thingies. (What is the real name for them?) What do I do? Is it the seals, or is the situation a lot more serious?
its most likely not a blown seal, but debris in the seal itself..
take an old piece of exposed film and slide it between the seal and the fork leg and try and scrape the dirt out..
if this doesnt help then its blown, but 99% of the time it just has crap in it
Try cleaning to see if a small piece of dirt could be breaking the seal. Do your forks have air bleed screws? Look on the top of the forks. You will have the compression damping adjuster screw (it may be label with H and S - hard - soft. You should also see another screw that is not labeled. That is your air bleeder screw. Remove it and you will hear a tiny bit of air come out. That releaves the pressure that builds up every ride. The extra pressure is sometime enough to make the seals leak. You should bleed the air after every ride. It's best to do it with the front wheel off the ground. If that doesn't work, you might need new seals. You would have to disassemble the forks to do that. I would have a qualified person do it because you need special tools to put the spring back in. Can I get some good gas?
Yeah, but how do I get to the seals? :busted:
I cant really help you with that. I havent needed to change my seals yet so I dont know how to do that yet.
you get to the seals by lifting the fork boots up. I've done the same thing heybuddy suggests, only with a needle going around the seal to try and remove dirt. The best thing I can recommend is a set of seal savers, the work great for keeping dirt and sh*t out of your seals.
they come with zip-ties to keep them from sliding off the lower tubes
I might invest in some of those. they looks way better than any fork boot.
Do you use the seal savers with the stock forks, or are those aftermarket forks? My uncle (from whom I bought the bike) says the forks are leaking because of the cold weather. I did ride the bike in the snow, and it did get really really cold (wind chills were around -15). The bike is garage kept; I don't leave it outside. He says all I need to do is add more fork oil and it will be fine. Is this accurate? How often do I need to change the seals? Can anyone post any links or something that can show me how to take the forks apart?
yeah you can use the seal savers with the stock forks, mine are on the stockers.
fork seals shouldnt have to be repalced for a longggggg time unless you damage them or allow debris to accumulate around them, eventually getting stuck in them and causing them to leak..
for the third time. clean them and see if it stops.
After I cleaned them they are still leaking. Is there any links or something that I can go to that shows me how to replace the seals?
  • Similar Content
    • By hondahondo
      A few picks of my winter project.
    • By Australian Psycho
      So I want to fit a Speedo to my stock Honda CRF230F, I know people have fitted the Trail Tech endurance to them but they are a bit pricey so my questions are is there another reliable Speedo or is my best choice to bite the bullet and get the Endurance? My other question is the stock stator for the CRF230F enough to power a Speedo or more specifically a trail tech endurance 2? I fully capable of installing it and splicing the wiring, my question is just can the stock bike support it? Also the Bike does not have a headlight.
    • By StreamZ
      I am in the process of slowly repairing everything on my 230 that had been bought from a farmer and obviously had no love ever in its life. Anyway, as I pull off one thing, fix it, reinstall it and then ride around again, I keep coming back to it not being the most aesthetically pleasing 230 on the planet. I was wondering if anyone has suggestions for sticker kits leave 'em below.
      FYI: I would like to keep it as stock looking as possible maybe even use the sticker kits from the last couple years of motorbike.
    • By Daniel627
      I hate finding awesome deals, but not able to make it happen!
      I found a complete '05 crf150f that I would love to get for the gf and get running. He wants $400 obo. It's a 7 hour drive though. I would have no problem making the drive normally, but even if he'd take $300-350, it would still cost me about $150 in gas. I can't really justify spending the money at this point in time and that sucks balls!
      I just had to rant for a moment
    • By Dumpdaveinfl
      Hey guys,
      Just  finished my xr and wanted to share some pictures with what I done. I have read a lot of posts on suspension for the xr, so I’ll share my mods.I got a set of dnm hornet forks from my wife on my birthday. With a new front I had to do a conversion on the back-so I went with a Crf150f swing arm that got off eBay. After some machine work in a Bridgeport mill removing 5/8 off each side it fit. I removed extra 1/4 inch to allow for chain alignment so it could be shimmed. The  frame was over drilled to 14mm and had to shorten the bolt by removing the bolt head and re-weld a nut to the stud. The shock is temporary until I figure linkage or direct mount but for now it’s a 11 inch fast ace 1100 lbs with adjustable rebound. Also for ease of service I drilled and taped the swinger and shock pivots with 6mm zerks. The wheels are the stock Crf150f and installed Ebc slotted brake pads.
      The DNM front forks were a challenge as no bearing combination would work with the 41mm race. I used a set of roller taper stock bearings and shimmed the bearing to the triple stem. Brake caliper had to be modified with a new bracket to use the 240 rotor. Also I have yet to find information to support these forks so if anyone has information on these please let me know..
      35inch seat height
      as for the rest of the build the motor has a engines only 120 kit with cam and slotted cam sprocket and mikuni tm24 carb. Shower head and oil pump by Daytona and alto red eagle clutch with bbr springs and a hydraulic clutch. Cdi and coil, new seals. installed a bbr  cradle with engines only aluminum front mounts. Had to remove 2mm off the engine and frame dowels to get these to work together. A new seat cover and foam with a clean up on the plastic. Let me know what you think. Thanks
