my clickers!
On my right fork tube, my compression clicker clicks in endlessly. (Clockwise)
Their are 24 clicks of adjustment. I can click it out (counterclockwise) to the end just like the other fork tube, but clicking clockwise is endless. The clicker goes in the same actual depth as the other one but keeps spinning.
Does anyone think I no longer have any adjustment on that fork tube or am I okay? It is an 05 KX 250.
Thanks in advance
I'd take it off and do a test by hand to compare.
what do you mean? my forks are off the bike.
exactly, compress the forks manually while messing with the clicker, compare to the other. dont know if you have lost the adjustment, but something is deffinatly broke
is it easy and cheap to replace? Is it a simple part? just like a water hose valve or something more complex? I am pretty sure I broke it too. I took them off to get them rebuilt. I decided I would see how many clicks I can go in and out. I kept clicking this tube in, it got a little stiff, I clicked it again, made a solid pop and here we are with no adjustment. another "Way to go Greg" moment.
Something is broken internally. The adjuster screw should bottom. It's probably no longer attached to anything.
On the 05's is the rebound up top and comp on bottom?
I know on my 01 the comp adjuster (bottom) is a pressed together unit that does not come apart. The rebound adjuster on mine looks like you could take it apart.
OK, so we can skip ahead now that we heard the story.
Yep, you broke it. You will need another fork cap.
Compression is on top from 05 - 07 (06 and on for four-stroke).
I did a similar thing when I got my first motorcycle. On my DRZ400S, I was setting all the clickers back to stock settings. When I got to the clicker on top of the left fork tube, I turned in expecting to feel a hard stop instead of the soft one that you actually feel. I ended up with a endlessly turning clicker just like you are talking about, only in both directions. I looked at a parts diagram of the fork to see what might have happened and for the DRZ400S, there is a shaft that connects between the clicker cap and the a valve down lower in the fork. I imagine I have stripped out something or become disconnected from that shaft. It would help too I bet if you look at a parts diagram of your fork. They have OEM diagrams for all the kawasaki dirt bikes at motosport, or if they have the OEM parts store back up here at TT they will have it too. I remember it went down for a while and am not sure if they are back up yet. Good luck.
PS-I have yet to fix my fork on the DRZ400S. I got more interested in my 2 stroke after I got it, so my DRZ is mostly a street bike and the fork setting is stuck wherever it broke I think...all the way on max compression...I will fix it someday.
For everyones info I took it back to the shop that put seals in it and they took the fork cap off and found the threads were stripped. They rethreaded it and told me not to go all the way in or it will happen again. But the adjustment is definitely their! All for no charge. Thanks for everyones input.
Sweet! Congratulations!
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
