2001 DRZ knocking?
Hello All,
I have a 2001 DRZ dual sport with 1400 miles. I've noticed that if it's at idle in neutral or clutch in and I romp on the gas, I hear a knock coming from the engine. If I gas it more normal then it does not do this. Does anyone have an idea what this may be? I recently got the bike so I'm not sure if this is normal or not.
Thanks...
Is this piston slap pretty common on the DRZ? Is it detrimental? This thing only has 1500 miles, so I'm kind of worried.
How do I raise the idle speed.
Thanks I appreciate any help...
The little knob on your carb will raise the idle...:busted:
I just bought a dr-z and i freaked out about the same noises. The bike just makes funny noises man, try not to let it get into your head. The engine makes a slight ticking sound and the pistons sound like a sowing machine.
As long as the bike runs good and the noises dont sound extremely load and nasty, your bike is fine. These suzukis are tough as nails but they all sound like they are messed up if you dont have a trained ear for the dr-z engine noise.
Slight ticking noise....???? You must have gotten a nice one...:busted::moon: The motors are noisy...A little scarry till you get to know it.
:mad::p
Erling
^^^:busted:
Very Very true.
I have a couple of SR500's that will make ya think...***??
My DRZ is actually pretty quiet.
Piston slap caused by a short piston skirt combined with "lugging" or low RPM....the DRZ likes to be wrung out a bit....you don't need to bounce of the rev limiter but don't be afraid to get the RPM's up.....
Lugging the bike is not good and yes over time could cause a problem.
Thank you very much guys!
I'm so glad I posted on this great site.
I was starting to think the bike was messed up. You guys saved my
Christmas. Heck, I may just go for a ride today....
:mad::eek:
Erling
:p &%$#@! :p
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
