2005 Exhaust Fit on 2006
You can if you move the mount on midpipe where it bolts to the subframe. Other than that mount the rest is the same.
Explain more please... I'd have to cut off the mount and reweld it?
Yes, or do as my friend did and weld a nut to the midpipe in the correct spot for the mount, then you would have to mounts on the midpipe and could swap the pipe to any YZ250F from 03-09 without any further modification.
