Husky 2008 TE510 - Summer Ride around Owyhee Reservoir
As all you Husky folks in the northwest are looking at deep snow and I'm stuck in West Africa for the holidays, I thought I would post to lighten up the mood.
This is an 'adventure' trip I've wanted to do for a while on my TE510 from Owyhee Junction to Jordan Valley in Eastern Oregon. I finally got around to it this past fall (September 2008).
The tricky part is the west side of Owyhee Reservoir including a ford of the Owyhee River.
Taking off from the Airstream near Owyhee Junction. Early start for a change !
On the dirt to Twin Springs campground with Grassy Mountain in the background. Done this many, many times and never really get tired of the views.
Coming down into the Owyhee River near the old Watson town site (abandoned). Nice cottonwoods and mosquitoes aren't bad at all.
Trusty steed kitted out with DirtBagz tank and fender bags, 2x 1.5 liters extra fuel and Motosportz midpipe guard / bash plate. I did carry an extra 0.5 gallons of fuel which I used at the 25 mile point to fill up. Lack of range is the most serious drawback to using the TE510 as an adventure bike, other than that I quite enjoy the ride.
Ford across the Owyhee River, flow at Rome, Oregon is running roughly 150 cfs during September. You wouldn't want to do this in the spring of course. The ford was a good gravel base. As I was riding solo I just dismounted and pushed the bike across the river.
On the south side of the Owyhee crossing after climbing up onto the rim. This is where the TE510 comes into its own as the 'road' is steep, rocky and rutted. Point, throttle up and go !
View up on the south rim looking towards "The Tongue". Lava all around, really cool. Owyhee mountain range in the background.
Quick run past the Cow Lakes and into Jordan Valley for lunch.
Trip back to Owyhee Junction ws via highway 95 and Marsing / Homedale / Adrian. Obviously the butt getting a bit sore at this point. 200 miles total. Finish the day in traditional fashion with an adult beverage and sunset view of Mitchell Butte in the background.
I gotta say that looks like a pretty sweet run, nice views
Thanks for sharing,looks too nice.
Sounds like fun, I'm jealous of your surroundings and beautiful views. I love reading stories like these, the american dream in action!
Iv'e rode the sucker creek camp area to three fingers and the resevoir,But never the big loop like you did!
Wow that's a long loop.
I'll put that on my list..
Great ride and photo's. Living in the Southeast, our geography is a bit different. Love those wide open spaces out your way.
I'm putting this on my riding "to do" list.
Later,
John
  • Similar Content
    • By 1madgerman
      Hi Thumpertalkers,
      Just making a thread where I can share my videos as I make them.
      I will start the post with posting a few old ones until I get some more new ones.
      I'm no expert by any means just have fun making and sharing videos!
      Thanks lars
    • By 305hestbeck
      So I just sold my bike 2017 TC250 with only 17 hours on it. When it left it was in brand new condition. But 2 days later the engine cases were being split.
      Turns out the Idler gear had snapped off during the new owner’s first ride. Of course I am not paying for the fix as one it is clearly a manufacturing defect. I told him If needed I would help by me claiming it as warranty issue.
      Anyways I did some research and discovered that the KTM/Husky expected a 6x12 to hold the idler gear sys together on 2017.
      Well this seems to be an issue and KTM did fix it for the 2018 models. They actually updated the whole Idler gear sys, but if you still have a 2017 2 stroke the fix before it happens which it could on the first kick would be to replace the bolt with a 6x20.
      You will have to tap the hole for more treads. Actually the 2018 engine case was also updated for this and that’s all they did.
      I own a 2018 TX300 now. One reason why I looked into it.
      Just thought I would share.
    • By Tranos07
      Greetings to everyone. After a lot of searching I finally decided to join this forum in order to finally find a solution to my problem. Here's my story. Bought in a hurry an sm610 2005 (cylinder with the small tensioner) which wouldn't start cold. Only if I connected it to a car battery would it start but not always and not easy. Got a new 14amp battery and nothing. Spark plugs,starting spray etc nothing worked out. If the engine was cold it would start in an instant very very easily. Took it to a mechanic he told me that it had no compression so he grinded the valves. When I got there to take it back he told me that my pick up coil was in bad condition and needed to be replaced in order to start cold. Of course nothing changed after the valve job and after 5 hours of riding(not constant) my new head gasket blew and when I took it apart I found a crack in the water passage on my head right next to the blown up spot on my gasket. I don't know if it was already cracked or if it cracked after gasket blew all I know is that it was tightened properly as I was in front when this happened. I'm just trying to figure out why i can't get it to start cold. All answers are welcome. I had the head fixed and I'm ready to reassemble the engine. Could the pick up coil actually be responsible for this? Another thing I noticed. My tensioner had an apostate welded up to it so i needed a new cam chain as well as a new tensioner. I have these. Could the ruffled chain be in charge? The engine was perfect when hot starting and working like a charm. Please someone help as I'm ready to take the damned thing and throw it into the ocean.
      PS is the pick up coil from an lc4 engine compatible?
    • By birdland101
      Restored 1974 honda xr75 original motor and frame podercoated frame runs, looks, shifts, stops good. top end rebuild many new parts most all honda. email birdland101@hotmail.com.
