What to do to a new to me 2000 XR100
I just picked up a 2000 XR100 for my son...It is his first dirtbike...He is 12 years old but a short kid. Right now the thing runs good as he does not need any more power at this level of learning...He has always had quads...He is coming off of a Suzuki LT80. I was watching him try it out the other day and he is very nervous on the bike but i know that will improve with time riding...I rode the bike a little and the thing to me felt completely gutless. Not like there is something wrong with it, just slow enough that if he had to climb a long kinda steep hill i dont think the bike could do it. I know he doesnt care yet but what can be done to improve the performance cheeply. thanks for all your suggestions ahead of time.
A big-bore kit and pipe will work wonders. Sure it doesn't need the top end freshened up? 'nutcase
That 132cc TB kit is worth trying. That will be some added punch.
420 chain and sprockets from a XR80,remove snorkel from airbox,Uni filter,rejet carb.,10w30 oil,XR80 wheels and tires.this should make alittle difference,and if that's not enough,like SoCal said,132 kit,Web or Powrol cam,and XR200 or ATC200X carb.
cool thanks for the advice. I am going to try the simple stuff before going with a big bore kit. What is the best sprocket tooth numbers front and rear to run for a little more top end. right now it takes off great but runs out real fast.
It's really personal preference I've been told.I'm using 13/46 with XR80 chain,sprockets,and wheels.I think stock is 14/50.I think 15/50 or 14/45 would be a good combination.The XR80 chain and sprockets made a pretty big difference in power or atleast it seems.My bike will wheelie in 3rd gear with alittle clutch,and I don't mean barely come off the ground.It will get up to the break over point.
Condor74,I'm sorry to thread jack,but I just oblonged the holes on the pick up coil on my XR100.Thanks to Shortstuff's info,my bike revs alot faster.It is raining outside so I only got to ride it about 10 minutes,but I can feel the difference.I told my son that I was going to make my XR100 faster than his CRF150F.
no problem on thread jacking. I am looking for any cheep aka free mods to make the bike more enjoyable. Any discussion leading to that is helpful.
Not to be to personal, but what do you wiegh compared to him? My wifes little 100 isn't any huge power house, but seems to have enough torque to climb a pretty steep hill.
Getting her completely tuned in may also help...adjust the valves, carb, things like that if it hasn't been done recently. Do a compression test just to be sure you aren't really down on compression, which is causing the decreased sense of power.
I weigh 165#,and my boy weighs about 110#.I ride a '06KTM525EXC when I'm not on the XR100.I bought the bike to keep the hours off my KTM(Hondas live forever).I race supermoto trackdays,and offroad,and some dual sporting for fun.
There are several guys(grown men)on XR100's,and they have a ball on the little bikes.All I have done to mine is rejet carb,mod the airbox,UNI filter,XR80 wheels,chain,and sprockets,advance the timing,adjusted the valves,and changed the oil.I think I have gained atleast 2 HP,or maybe lost 2lbs?I just got my 200X carb from the mailbox.A new cable,and throttle housing are soon.Maybe I'll gain another 1/2HP.lol:thumbsup:
I weigh around 180 in full riding gear and ride a CRF250X with mods done to it. My son is around 80 pounds soaking wet. I got out and really rode it hard yesterday and it was a blast. once i got it into top gear it ran pretty fast. It seems to just have a really narrow power band that has mostly all low end power. I got fast enough that i was worried about the bikes suspension being able to soak up bumps at that speed. He is an extreme novice at this point so to me the bike is about perfect.
I wouldn't mess with the gearing just yet. In stock form the XR100 will climb just about anything out there. To me mild hill climbing and tight technical trail riding is where the XR100 does best. Change the gears for more top end and you compromise the afore mentioned abilities and put the bike at a higher speed where the suspension just doesn't cut it.
  • Similar Content
    • By spezza-125
      Anyways so I got a 1985 xr200r RFVC, and I have heard that the oil really overheats and in some cases people have had their bike (Rarely) go up in flames, however I don't want to take any chances and I heard that there is a way to put on some sort of oil cooler... How do I do it??
    • By Yamiha
      I have a '01 XR200 and i was wondering it anyone could give me a top speed for it. Where i live its more 2 lane highways and things so i cant find a good straight to run it with a car in. Thanks
    • By Quick Draw
      I decided to compile a list of common modifications for the XR200 in hopes of eliminating some of the common questions asked on this forum. These modifications are intended to improve the overall performance of the bike, without sacrificing reliability. Feel free to suggest amendments or things to edit.
      The XR200 is an excellent offroad machine; however, it was for the most part obsolete about 20 years ago. The bike can still be accredited to having probably the best reliability of any full size bike out there. When properly setup and modified, the "little XR" can run with the modern big bikes, especially in the tight and nasty technical terrain.
      INTAKE: Remove the airbox snorkel on top of the airbox. It just takes a little prying and it's out. For $20-$40, you can get an aftermarket filter (UNI, TwinAir, No Toil), that will help increase airflow. Rejet one size up on the main and pilot.
      Here are the stock jetting specs to give you a basline:
      Stock jetting
      XR200 (not XR200R)
      main 102
      pilot 35
      Needle position 3rd groove
      Pilot screw initial setting 1 3/4 turns out
      XR200R (81-83 only)
      Main 138
      Pilot none
      Needle position 3rd grove
      Pilot screw initial setting 2 1/2 turns out
      XR200R (86 and later)
      Main 112 (86) 110 (87 and later)
      pilot 38 35(98 and later CA only)
      Pilot screw initial setting 1 1/8 turns out
      When these things are done, the bike will breath much better. This is the single greatest modification for a bike ridden at high altitude.
      Overall cost w/out filter: about $10 for jets; $20-$40 for the aftermarket filter
      ENGINE: The greatest improvement to the XR200R engine is a big bore kit. Here are the 2 most common kits: http://www.powroll.com/P_HONDA_XR200.htm
      Other options include porting and polishing the head, high compression pistons, hotter cams, etc. The more you do, the more reliability is reduced, but it is a trade off for power. Another option is an ’83 -’85 ATC200X cylinder head. It has a .5mm smaller bore, so it would need to be bored to 65.5mm, however, it has much larger cooling fins. For motors that are constantly being run in extreme temperatures, this is an option to consider.
      Overall cost: Varies by modification, expect to drop $200-$1000
      EXHAUST: There are several aftermarket exhausts on the market. These range from silencers to full systems. Prices range from $80-$500. Most aftermarket exhausts will give about the same improvement. The engine will rev quicker, which can be nice, but mostly they all just make the bike louder. For mild improvement to the stock system: grind the weld off of the inside of the header and remove the small cap held on by 2 8mm bolts at the exhaust tip.
      Overall cost: 0-$500
      SUSPENSION: This is a major weakness with '92-'02 XR200s. The first option for the forks is to give the springs more preload by adding a larger spacer on top of the springs. The second, most common option is to swap out the entire suspension. '84-'91 XR200 forks and rear shocks will bolt right up, and ‘81-’83 XR200R forks will with the corresponding triple clamps. '84-'89 CR125/250 front ends will bolt up to any XR200R with the addition of a spacer. This particular swap is more complicated, but also adds a disc brake and improves the bike tremendously when used in combination with an '84-'91 XR200 rear shock. See this thread for more info on CR front ends: http://www.thumpertalk.com/forum/sho...1&parentpage=2 These parts frequently show up on Ebay and can be obtained very cheap. Also, a visit to racetech.com or similar suspension tuning company couldn't hurt with any setup. Emulators and progressive springs will get conventional forks nice and plush. Currently, XR250 rear shocks are in question as to what years will work; therefore, I do not recommend them at this point. Many people have them on their 200, however there is not a definitive answer for the years yet. Be sure to research before you buy.
      Overall cost: Generally less than $100; for Racetech tuning, expect to drop $200+.
      WHEELS: An 18" rear wheel from an '86-'89 XR250 will bolt right up. This can help because the 17" wheel spins too much sometimes, and tends to work its own spokes loose. There is also a much greater tire selection with the 18" rear wheel.
      LIGHTING/DUAL SPORT: Lights can easily be added to the 200 by tying into a pink wire that just comes up under the tank, then loops right back down to the stator. This wire has no purpose, and was left behind in the wiring harness, because the non-American XR200s had lights, and Honda didn't pay to change the wiring harness or the stator. I have personally tested it up to 75 watts, but I wouldn't recommend going much higher. From there it is simply a matter of wiring it the way you want it. In any application you will need a 12v voltage regulator. I would be happy to assist with any questions on the wiring you may have, since I have redone mine several times to change things. Also, please visit this thread for some diagrams (about halfway down the page): http://www.thumpertalk.com/forum/sho...d.php?t=431097 Each wiring job is different, so it is difficult to write a generalized way to do it. For dual sporting, there are kits from Baja Designs and similar companies, or you can be creative and pull parts together yourself, and in result save lots of money. The first time I had lights on my bike, it only cost me $6. A speedometer cable can be attached to the speedometer port on the front brake hub, as long as you can find a way to mount the speedometer. TrailTech computers are the easy alternative to the manual speedometer.
      Overall cost: Dependent upon creativity. Baja Designs kit runs around $450
      Helpful XR200 Links:
      www-staff.lboro.ac.uk/~elvpc/papers/XR200.html (engine info)
      http://www.4strokes.com/tech/honda/lightup/ (adding lights)
      **I need more links for XR200 INFORMATION, NOT PRODUCT websites....Post them in this thread if you have them***
      Again, please feel free to suggest editing....I'm sure there are MANY things I forgot. This is just a baseline to get started.
    • By Footy
      I don't have photo access yet but lets see your 200's.
      My dad is planing on selling his 02 XR 200, but it's in need of a rear shock. I was told that these shocks arn't servicable, so we priced a new one out. The dealers asking over $400 for a new one. So my question is, what other bikes have a rear shock that will work on his 200? Thanks.
